100W Ultimate Fidelity Amplifier
Old 20th August 2019, 08:06 AM   #11731
rehman is offline rehman  Pakistan
Originally Posted by cl00sed View Post
Thanks all who helped in solving my issues, now AX14 amp is working good and the bias is set to 12mv
DC offset - Itís like less than 5mv
Raj
can you tell me what you have did. i have ax17 but unable to adjust bias no voltages are appeared on meter no matter how much and in which direction bias pot is turned.
Old 20th August 2019, 09:00 AM   #11732
prasi is offline prasi  India
prasi's Avatar
Raj, can you post what was actual issue and how you solved it. It will help others.
I had Rehman in mind when I posted this but he was quicker to ask.
Also SQ impression with your good speakers when you hook them up?
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 20th August 2019, 09:56 AM   #11733
hi sir
i was reading some previous posts about ax17. i faced about the same issue in adjusting the bias and dc offset. i will try the given instructions. my pcb is without dc servo, also there is another amp ax15. iam thinking to make it. there might be no issue in offset and bias adjustment with ax15. it it true?.
Old 20th August 2019, 10:02 AM   #11734
cl00sed is offline cl00sed  India
I followed the 11683 procedure, earlier i havenít connected the signal ground to chassis ground.
After connecting it DC offset from 15mv on one channel is dropped to 5mv.
Sure prasi after connecting it to my main speakers will share my review, as i do t have speaker protection so did not want to take risk
Raj
Old 21st August 2019, 06:51 AM   #11735
have any one made ax15? iam thinking about it too. what would be the sound comparison of ax14 and ax15?
Old 23rd August 2019, 07:28 AM   #11736
Gurpreet Turna is offline Gurpreet Turna  India
Apex Fan control PCB with photosensitive dry film
Old 23rd August 2019, 01:46 PM   #11737
prasi's Avatar
Go for a different topology if you want something different, like apex studio reference or AKSA quasi-complementary mosfet amplifier or DIYA honeybadger.
Old 23rd August 2019, 02:37 PM   #11738
I think you are right. After making and listening to a40 with p30 , ax 20, ax 17, and ax 14, i want to try something different. i should definitely go for different topology. i am also missing my headphones because headphone jack of my laptop is not working and i don't bother to fix it. i have decided to make a headphone amplifier.
Old 23rd August 2019, 02:54 PM   #11739
Yesterday i have connected AX-14 with my main speakers and found like left channel is having more gain than the right channel
Any suggestions to solve the issue?
One more observation is when i switch on the amp with out connecting the signal input there is thumb and hiss sound - is it normal?
Raj
Old 23rd August 2019, 07:53 PM   #11740
ChrisMmm is offline ChrisMmm  New Zealand
ChrisMmm's Avatar
I found the AX14 very well behaved, not a sign of switch on/off thump.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Copyright ©1999-2019 diyAudio
