100W Ultimate Fidelity Amplifier
Old 16th July 2019, 02:30 PM   #11521
Sunny22g is offline Sunny22g
Originally Posted by still4given View Post
I checked and I actually used a modified version of the above layout. I really just simplified a little as Alex had designed it with two different sets of holes for the resistors and caps. I removed the extra holes to make it easier to etch and drill. I am adding those file here.
These are also for toner transfer. I you need photo sense files let me know.
Sir please upload ax40 file
Old 16th July 2019, 03:10 PM   #11522
still4given is offline still4given  United States
still4given's Avatar
What is it that you need?
Old 16th July 2019, 03:14 PM   #11523
Sir I need because I made 1 channel .When I unplugged power transistor .Then no short . Serious bulbs light up like normal .But when I add 1 pair bulb full bright.ichek transistor. .That is ok
Old 16th July 2019, 04:19 PM   #11524
Not sure what file you need but here is what I have. It is A40 not AX40.
File Type: pdf A40 CFA APEX TOP SILK SCREEN MIRRORED.pdf (329.3 KB, 33 views)
Old 18th July 2019, 01:42 PM   #11525
panggih is offline panggih  Indonesia
Thanks,I will compare mine file with yours file🙏🙏🙏
Old 18th July 2019, 02:00 PM   #11526
after I compare it with my files, the difference is only in R DCoffset,I use 470r as on the layout
Old 18th July 2019, 02:39 PM   #11527
HatlessChimp is offline HatlessChimp
Thanks to ChrissMmm I have started my AX14 build.100W Ultimate Fidelity Amplifier
I had to order more tombstone resistors in 0.33r. The 0.22r is for the Honey Badger that I'm also building (green board).20190718_213033.jpg20190702_193420.jpg
Old 18th July 2019, 06:56 PM   #11528
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
it should be 470kOhm or it will be ridiculously heavy to adjust dc offset nice and stable.
Chop your own wood and it will warm you twice
Old 19th July 2019, 02:21 AM   #11529
Ok I will replace 470r with 470k,
and for bias problems that continue to rise maybe because I use a mje350,340 transistor, bd139 fake.
Thanks for information🙏🙏
Old 19th July 2019, 02:31 AM   #11530
https://www.diyaudio.com/forums/atta...1&d=1563503007
This is A40 mine.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Copyright ©1999-2019 diyAudio
