100W Ultimate Fidelity Amplifier
Old 5th July 2019, 08:18 AM   #11431
Astaro is offline Astaro  Russian Federation
Astaro's Avatar
ChrisMmm С9, с10 change on 22-33pf. R20 change оn 50R. Sound will be better.
My lord - Lord of Silence
Old 5th July 2019, 11:28 AM   #11432
hassan4119 is offline hassan4119  Iran
Originally Posted by bullittstang View Post
This 150r to 470r stopped the power-on noise? To clarify, you changed R9 from this schematic/board layout? I am having similar issue, but negative DC for about 1-2 secs, pulls the woofer in. Hardly any real noise, but if I can avoid I would like to.
i can not kill popup noise.but when replace 150R/R9 with 330R or 370R mje350 and 2n5551's dont be hot....and circuit be stabl.but with 470R sound be very bad...because drivers can't work properly.you use 330R.
i dont know that how kill popup noice...mr mile just can help us.mr mile if you hear me heeeeeeellllpppp us please.
Old 5th July 2019, 06:33 PM   #11433
MilanAudio is offline MilanAudio  Czech Republic
So I decided to go also with APEX AX14
I have just two questions:
1) Where is the latest APEX AX14 PCB layout please?
2) What should be the bias on which resistor I should check mV?
So many posts here, I got totally lost...
And thanks for help!
Old 5th July 2019, 07:46 PM   #11434
AdeS is offline AdeS  Brazil
AdeS's Avatar
Prasi have shared gerbers here.
Old 5th July 2019, 08:38 PM   #11435
Amazing! Over 1100 pages and you knows! Thanks!
And do you know where I should check mV for bias (or what is it)?
Old 5th July 2019, 08:51 PM   #11436
bullittstang is offline bullittstang  United States
Measure across the 0r33 resistor and youíre looking for ~10mV, which should get you close to 30mA on the outputs. Thatís my figure, other may suggest higher or lower, but that a safe bias voltage.
Old 5th July 2019, 09:42 PM   #11437
ChrisMmm is offline ChrisMmm  New Zealand
ChrisMmm's Avatar
Originally Posted by prasi View Post
Yes, the amp is good to go. Few have it built and using. I haven't built it yet, but plan to.
30-0-30 , 300VA is good for 100W at 8 ohm.
Thanks prasi, will get ordering now.
MilanAudio, I ordered AX14 boards from PCBway and ended up with too many. If you would like I can send you a pair, no cost. PM me.
Old 6th July 2019, 04:49 AM   #11438
ChrisMmm's Avatar
All my spare AX14 boards have been taken now. That was quick!
Old 6th July 2019, 10:16 AM   #11439
anoopkrajan is offline anoopkrajan  India
Default AX14 minimum voltage
Originally Posted by apexaudio View Post
AX14 will work with +/-38V on 4ohms load without any changes.
What is the minimum voltage with which AX14 would work fine ?
Old 6th July 2019, 05:22 PM   #11440
lomdwrrrt is offline lomdwrrrt
Lord mile could show scheme dc6 protection
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
Copyright ©1999-2019 diyAudio
