100W Ultimate Fidelity Amplifier
Old 27th December 2018, 03:55 PM   #10851
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Originally Posted by sumeshak View Post
Tests completed...?
yes. i made a mistake at MM-MC phono preamplifier,so later i will post corrected files. i have also decreased current of a-class shunt to achive less heating in inclosure by increasing 22r to 47r (for pair of phono) and to 62r (for preamp with tone controle). i have put 22k at input of preaplifier with tone controle and a switch with 18k in parallel with that 22k to achive amlifying ratio of 1 and 2,2. it is not necessary but that is what i wanted.
YouTube
File Type: pdf MM MC bakar gledan kroz pločicu sa strane elemenata.pdf (66.5 KB, 64 views)
Chop your own wood and it will warm you twice
Old 27th December 2018, 10:41 PM   #10852
44250's Avatar
I have listened MM MC for a few hours now,and my first impressions are really good! I am not to experienced with phono theme, I had one phono preamp before this one. it was IC-based and it had (at my opinion) too much amplifying and it bursted a bit at high frequencies. MM MC does its job much more natural and pretty equally at all frequencies, from bass to treble. i think it should have a bigger amplifying ratio but it is quite enough as it is,all in all. for sure,it is a step further than I was until now.
Preamp with tone controles works also really nice,and whole system is really quiet even with everything on max and with MM MC as a signal source. quite pleasantly surprised!
Old 30th December 2018, 02:09 AM   #10853
eliasib is offline eliasib  Venezuela
Hello friends. I want to build the HX-11 class H but I would like to make some changes such as adding a pair of transistors more per rail (total six transistors) to make use of a big transformer that I got from an amplifier. I think one of the changes I have to make is replace the diodes that pass +/-VL. The power supply provides +/-35V, +/-75V. Any suggestion, I would thank you.
Old 1st January 2019, 08:35 PM   #10854
maxwell007 is offline maxwell007  Czech Republic
maxwell007's Avatar
Guys, I still fighting with one channel of my Apex A40.. I am able to set bias,offset, but when i increase voltage over +-9V signal looking very strange... :-) I did some mistake before, mostly solved...any idea?
Old 5th January 2019, 09:31 PM   #10855
44250's Avatar
have you resolved problem? I have had problem with bias stability but oscilloscope had not showed me such problems... i do not know what would be a problem in your case, but it seems it is in "positive" side of power amplifying, I would start by checking that side of an amplifier board. compensations on that side,transistors pinout, value of resistors at their place... i have had problems with different markings of capacitors, so instead of (in my that one case) 330pF I have installed 33pF. manufacturer of capacitors I have had in that moment marks capacitors in a different way than others, and I have bought them as 330pF. naturally, amplifier had "seen" that and it was not glad,so it had oscillated.
Old 10th January 2019, 08:56 PM   #10856
doityourselfamp is offline doityourselfamp
hello
i need a hayberide preamp with tube and transistor
the sound must be warm and best quality
any one have sugestion please?
Old 10th January 2019, 09:21 PM   #10857
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 100W Ultimate Fidelity Amplifier
Originally Posted by doityourselfamp View Post
hello
Pls contact @vzaichenko
Virtual Zero Audio Store
Max.
Old 16th January 2019, 04:57 AM   #10858
rankot is offline rankot  Serbia
rankot's Avatar
Originally Posted by prasi View Post
please find attached herewith pdf files and other documents.
Which version of schematic is this? 14, 14.1, 14P or something else?
Old 16th January 2019, 05:03 AM   #10859
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Amplifier is unstable and breaking into oscillation.
Increase C9/10.
R21/22 can affect oscillation too, I usually use 10R in those positions.
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 06:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 05:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 03:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 03:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 12:54 PM
Copyright ©1999-2019 diyAudio
