100W Ultimate Fidelity Amplifier
Old Yesterday, 10:27 AM   #10771
kandimba is offline kandimba  Portugal
Originally Posted by macd View Post
Good Day Sir Apex and Kandimba....
I have completed my second channel of my AX20P amp. Second channel is working, adjust bias current to 20mA. Sound is great...
When I measure the offset voltage on output, the first one is 15mV and I get a 0mV reading on my second amp. Is this normal/OK ????
Second Question.... When I play my first amp at full power, clip LED goes ON but amp is still playing sound. When I play my second channel at full power, when the clip LED comes on, the relay disconnects the second speaker and only one channel is playing. What can be the problem? At first I thought it is the thermal cut out, but the amp is still cold when this happens ....
I am not sure if the one channel is faulty, maybe overload protection is not working or if the second channel's overload protection is to sensitive???
Thanks in advance...
macd
I MACD, about DC offset is OK. The first channel is ok, because when clip led goes on, amp should stay playing. You should see what you have done in second one, and compare with first one. Maybe you have put components in wrong places
Old Yesterday, 01:16 PM   #10772
macd is offline macd  South Africa
Default RE AX20P Question...
Hello Kandimba...
I will double check everything again tonight and give feedback...
Regards..
MACD
Old Today, 08:40 AM   #10773
Bangla H is offline Bangla H  Germany
Bangla H's Avatar
Default FH9 Pads
Click the image to open in full size. Apex FH9 gerber help?
Hey guys is there anyone who can import the Apex FH9
Gerber file from ver 1.05 and fix it to have thru hole plating
And solder pads for both sides?
Right now the gerber link has no thru hole plating or pads top side.
Hi Scott
may this new routed Board will work for your need.
It is mostly followed by Sonal traces, but added above traces.
Have fun.
I place my orders to KiKiPCB, like vargasmongo.
Regards.
send from my NOTEBOOK PC.
Old Today, 12:31 PM   #10774
bigaudioscotto is online now bigaudioscotto  United States
Thank you for the Gerber.
Scott
Originally Posted by Bangla H View Post
Hi Scott
Have fun.
Regards.
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 06:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 05:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 03:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 03:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 12:54 PM
