100W Ultimate Fidelity Amplifier
Old 17th October 2018, 01:15 PM   #10731
Vrystaat is offline Vrystaat  South Africa
Originally Posted by macd View Post
Good Day....
Thanks to Sir Apex for the AX20 circuit and a Big thanks to Kandimba for the PCB Layout....
Completed AX20P....see pics attached....
Thanks Sir Apex and Kandimba.....
One question....how much bias current for this circuit???? How do I adjust the bias current??? Here is what I am doing....
I measure with DVM across 0.33R resistor. I use ohms law...V=IR...6.6mV=20mA x 0.33....Is this correct????
macd.....
Yip, math is correct !
Jan
Old 17th October 2018, 08:21 PM   #10732
HIFI0101 is offline HIFI0101  Bangladesh
I was thinking if i build the A40 with good caps like nichicon kz and other original good components. What is the price range of comercial amps it can compete with or is diy amp are just a fun thing? :/
Old 18th October 2018, 06:13 AM   #10733
macd is offline macd  South Africa
Good Day....
Can someone please guide me to balanced input schematic as I would like to drive amp with mixer with balanced outputs...
Thanks in advance....
macd....
Originally Posted by apexaudio
Good Day Sir Apex....
Thank's for all your audio designs...I am very grateful...
I've just completed an AX14P and an AX20P amp design, both using Kandimba's PCB layouts... Both amp's have great sounds...
Just one Question... I have a mixer with balance outputs. How do I connect mixer's balance output to input of amplifiers?
macd.....
Class D Amp with LM566, LM393 and 2XIRF530
Good Day Sir...
This is what I was looking for...Thanks again...
Just some feedback...I connected my AX20 yesterday with proper speaker and supply. Sound is very nice, but I like AX14 sound more. Better trebles and bass. Tested both AMP's with same setup...same psu, input mixer, speakers.... AX14 my favourite..
Thanks again for all your designs...
macd
Old 18th October 2018, 01:15 PM   #10734
kandimba is offline kandimba  Portugal
If you change R16 1K to 1K5 you may get higer bias, 15mV on R23 .33
Old 19th October 2018, 01:02 PM   #10735
Default Ax20...
Thank you Kandimba,
I will test tonight with 1K5 resistor....
macd
Old 19th October 2018, 01:10 PM   #10736
Sunny22g is offline Sunny22g
Macd can u give layout
Old 19th October 2018, 01:19 PM   #10737
no problem...not my layout, Kandimba did the layout...work's 100%..build as is....you will not be disappointed...lot's of power...
macd....
Old 19th October 2018, 10:24 PM   #10738
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
it is all about a lot of power all around anyway....
Chop your own wood and it will warm you twice
100W Ultimate Fidelity AmplifierHide this!Advertise here!
Good ~100W amplifier percy Solid State 16 3rd April 2013 05:16 PM
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
Ultimate Amplifier DF Plummer Tubes / Valves 19 23rd March 2011 02:48 AM
Ultimate amplifier glen65 Car Audio 2 19th September 2007 02:15 PM
100W Amplifier Shematic and PCB viki Solid State 2 17th October 2004 11:54 AM
