900W H-class PA Amp with Limiter
Old 14th April 2019, 02:11 PM   #3721
masood251 is offline masood251
Originally Posted by apexaudio View Post
Input GND missing! Amplifier can't work without connect input GND. I can't see wire jumper (red line on component layout) on botom side of pcb, somethimes I forget connect that wire.
Hi sir
Good evening i have completed h900
before 2years but now i have time to check it.i have problem my dc voltages are at without load is 66v dc and 115 v dc after load voltages becomes 37v dc and 77 v dc what the problem please solve me.thanking you.
Old 16th April 2019, 02:43 AM   #3722
Finally i success in making h900 after changing 2n5401 and its 100 ohm resistance.But how can i know that my stepper is working.please help me.thanks
Old 16th April 2019, 06:06 AM   #3723
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
put some high input signal and measure output voltage.
Chop your own wood and it will warm you twice
Old 17th April 2019, 04:35 AM   #3724
At ab class mode across 100ohm volts are o.25 and at mje340 collector emitter 1.6volts just half as mentioned in apex circuit.thanking you
900W H-class PA Amp with LimiterHide this!Advertise here!
900w amp module for sale nigelwright7557 Swap Meet 1 15th May 2017 09:36 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
200w Amp + 900w Sub = explosion? 56k Warning Daemonicus Subwoofers 2 31st May 2006 04:30 AM
Copyright ©1999-2019 diyAudio
