MOSFET Amplifier IRFP240/IRFP9240
Old 21st April 2018, 01:27 PM   #1061
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by makus ele View Post
i need a powerful +-113 v Amplifier pcb i will use 11 pairs of 2sc5200
1000W Simple PA Amplifier
Old 21st April 2018, 07:48 PM   #1062
makus ele is offline makus ele
Originally Posted by apexaudio View Post
This PSU was used in time when I building this mosfet amplifier. There is PSU, DC and overload cut-out protect for each channel and soft-start for toroidal transformer. This circuit can be used with any amplifier.
how does overload cut-out protect works
Old 22nd April 2018, 07:05 AM   #1063
thanks for your help apexaudio
Old 24th April 2018, 06:11 PM   #1064
i need a speaker short-circuit protection
Old 23rd July 2018, 01:33 AM   #1065
silvestre101 is offline silvestre101
where does the protect go and what diode goes in the clip ciruit
Old 25th July 2018, 08:43 AM   #1066
apexaudio's Avatar
HV12
Old 25th July 2018, 08:55 AM   #1067
apexaudio's Avatar
HV12 schematic is in post #1023
Old 11th October 2018, 10:05 AM   #1068
mprivitera1 is offline mprivitera1  Italy
Hello guys,remember me the post where I explain BIAS regulation?Thank you
Old 11th October 2018, 07:02 PM   #1069
steveu is offline steveu  United States
Smile thermal compensation
Originally Posted by event horizon View Post
Ok, im not doubting you Q9 & 10 are effectively emitter followers though, if you mount them on the same heatsink as the output transistors surely they can't compensate for quiescent on the output stage?
Perhaps i'm having a stupid attack due to a few beers My apologies if this is so...
Actually , the thermal ~stability comes from D1,2,3,4, because the cross-over bias is dependent on VAS current which is a function of the diff-amp current, and one diode drop is across the current source(s) emitter resistor.
I'm not fond of completely symmetric front ends because there is so much bias dependency from one stage to the next and requires VAS emitter resistors. And according to some simulations I've done, there is no huge advantage in distortion that you would expect. And we know that symmetry cancels even order harmonics, which are "pleasant sounding", vs odd harmonics which are not. Harley Davidson sell a lot of motorbikes because the engine "defect" is very musical.
Years ago, Sinclair modules used a single resistor for cross-over bias and depended on the thermal compensation from the VAS current source, and that was a BJT circuit. Now, they blew up a lot because the output transistors were tiny and the system grounding critical, prone to oscillations. But they sounded great when they worked. That was my "previous life".
MOSFET Amplifier IRFP240/IRFP9240Hide this!Advertise here!
IRFP240&IRFP9240 power amplifier schematic mos Solid State 31 26th June 2012 08:21 AM
IRFP240 / IRFP9240 MOSFETs danieljw Swap Meet 8 4th July 2009 01:51 AM
Wtb: Irfp240 / Irfp9240 folkeb Swap Meet 1 10th March 2009 10:18 AM
IRFP240 + IRFP9240 -- pairs jackinnj Swap Meet 1 2nd June 2006 02:22 AM
IRFP240 and IRFP9240 Wanted richeros Swap Meet 1 9th November 2002 12:38 PM
