Dear ALL, to my ears it sound very well but how does it position in the world class hi-end ?
If you do not know it maybe I can send a layout picture ?
Maybe its easyer to understand the level of the product looking at how is it internally made out.
Thanks for commenting and I am ready with pictures in case
Specs are:
Max output level 35 V RMS
Output stage impedance <10Ohms
Corrected output inpendance 600 Ohms
Response for any level till 35 V RMS: +/-0.1 dB, O-150 kHz
Group delay: propagation delay <300 ns stable from DC to 200 kHz
Distortion at all values: dynamic TID <0,01% (-80dB)
Slew rate >500V/us
Rise time: <700 ns
Separation >90dB
S/N >85dB (0.01Hz-10MHz)
Weighted asa A >90dB
Specs are:
Slew rate >500V/us
Rise time: <700 ns
Separation >90dB
ad010685 said:Dear ALL, to my ears it sound very well but how does it position in the world class hi-end ?
Did you compare the pre with others ?
Blind tests?
Is positioning really important to you? I can understand, but in the end let your ears decide.
The specs look good to me, but other spec-gurus (like peranders) will be able to tell you more.
Pictures, as always are welcome.
/Hugo
