New Amplifier - ULD Extreme
Thread Tools
Old 28th January 2011, 06:00 AM   #451
ostripper is offline ostripper  United States
ostripper's Avatar
Originally Posted by VHF man View Post
Hi OS
The f14 ferrite needs to be in series with the vas emitter and preferably as close to the vas device as possible. If you use a small emitter resistor on the VAS then the f14 or F25 bead could be installed over the resistor lead closest to the VAS transistor.
Dave VHF
So integrate it with the degeneration resistor that is VERY close to the main VAS device (R17 below) ?. Insulate the resistor lead and pass 2 turns through the f14. Just to be sure ... is this a f14 ??
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
BTW , you realize this amp has "magical sound". I can't get over it ... had to get new tweeters and mids (below 1)to fully realize just how accurate it's sound was. Near perfection. I will share the final design (below 2 - r25 is just to test CCS current , not on real amp)... 0 thump (not even a "glitch" on the CRO) , 0 offset (0c - 60c) , can't be overdriven , and 100% awesome sound. It will run from 10V to 80V rails maintaining it's 6mA CCS current.
I've built every voltage stage out there and this one stands out. I can swap stages in 30 seconds , so I KNOW.
OS
Wanderer - GREENAMP , less is MORE.
https://www.diyaudio.com/forums/soli...ss-output.html
Old 28th January 2011, 07:22 AM   #452
Ian Finch is offline Ian Finch  Australia
Os, those TV baluns look the part, grade-wise. If they were for VHF reception, rather than just UHF, they'd be suitable. If you have access to the ARRL handbook in some form, it's usually a great guide to ferrites. I see there's some guidelines there too in the catalog you posted. The 6-hole "bead" Dave is using is, in my example, 6mm dia. x10 long.
Old 28th January 2011, 07:54 AM   #453
VHF man is offline VHF man  Australia
Originally Posted by Ian Finch View Post
Thanks for the comments
A great opportunity, eh? I did the same with ACE Radio in the late 1980s. Indeed, I have a number of those 6-hole formers and wired ones too. There's quite a bit more material in those than your average bead, however. I imagine it would take 2-3 beads of say 3.5 x5 mm to approach those big'uns. It's just well I asked.
Yes they are probably 3x standard beads. I will set up a bread board test cct and sweep Z over 1-50 MHz. I should also really use a 10mA dc bias to better simulate a VAS environment.
Old 28th January 2011, 08:42 AM   #454
Originally Posted by ostripper View Post
So integrate it with the degeneration resistor that is VERY close to the main VAS device (R17 below) ?. Insulate the resistor lead and pass 2 turns through the f14. Just to be sure ... is this a f14 ??OS
If it's sold as a vhf grade former then yes it's probably what I call F14.
It's a specific blend of nickel + zinc that's effectively lossy > 10MHz.
NAL F14
Old 28th January 2011, 12:29 PM   #455
Default Fair -Rite ferrites
This would seem to be the equivalent part in the US. The nearest standard Ni/Zn grade is 43 and fig. 1 (unwound) appears identical. As Dave suggests, a few smaller, plain beads may suffice. I guess we'll hear shortly.
Fair-Rite Catalog | Wound Beads
Old 29th January 2011, 12:17 AM   #456
Harry3 is offline Harry3  Australia
Murata also offer filtering solutions
Noise Suppression Products/EMI Suppression Filters | Products | Murata Manufacturing Co., Ltd.
Old 24th July 2016, 07:58 PM   #457
fachir is offline fachir  Romania
fachir's Avatar
Re-upload sprint layout files!
  Reply to this post
New Amplifier - ULD ExtremeHide this!Advertise here!
Thread Tools
Now THIS is tube DIY to the extreme LukasLouw Tubes / Valves 2 20th February 2008 12:03 PM
good ESL amplifier that works with extreme capacitive loads thadman Solid State 2 31st January 2007 11:20 PM
HEATSINK extreme cumbb Pass Labs 4 17th May 2006 02:14 AM
Extreme DAC 3.0 martioz Digital Source 3 11th March 2003 10:45 PM
Really, really extreme phono, more extreme than mine peranders Analogue Source 34 22nd October 2002 11:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
