Steve,
I'd recommend Columbus Radio if you want to stay local. This is a specific problem though, and I'm not sure if they have seen it before. They're really getting up there in age, but still seem to be in business. Do you have any experience yourself? I could probably help out, though not being a pro I hesitate to work on other people's equipment. I do have test equipment and access to an ultrasonic cleaner.
Steve.
Steve.
anatech said:Hi Steve,...
"One is 21.3 Ohms, the other is 11.3"
That isn't right either. There are resistors from RCA shield to ground, so these may need to be replaced. The only other thing I can think of is that your meter and / or probes are not reliable and may give varying readings on the resistance function.
-Chris
Chris, after a few hours warm up which perhaps they needed: If I place the digital multimeter's red probe on the RCA Ground, and the black on the speaker ground terminal, I get 8.4, if I reverse the probes I get 2.6. The other amp yields 21.2 and 0.00?
What's up with that?
Steve
spind said:Steve,
Steve.
Steve,
Columbus Radio sounds like a plan. I have met them before, too. I called and spoke on the phone, described the problem, the degree of DC offset and that the boards probably were never cleaned properly. He is busy to Christmas and a trade show after but I told him I would bring them round in mid-January.
Steve
Steve
there is no any connection with warm up .
anatech told you to measure that with amps powered off ....... at least some time , to let all caps to discharge .
just find capable tech .
otherwise you'll obviously stack with them , or even make some greater damage - either to amps or speakers .
welding machines aren't for fun .
Right. I thought he meant without speakers or line in.
That being said one is 5.5 the other 10.3
Zen Mod said:just find capable tech .
I hear that. Lucky once, I guess.
Hey Choky,
Hi, and thank you. You do get around! One of these days I am going to try your ...... SHUNTY! Looks pretty good to me to examine, poke and prod.
Hi Steve,
You must measure with the amps powered off and discharged. Any voltage across your speaker terminals will interfere with your resistance measurements. In other words, you will make silly readings that don't make any sense at all.
In the mean time, do not use your amplifiers! Never use any equipment that is not operating properly. To do otherwise may simply end up costing you a great deal more money. Beg, borrow or steal (not really) another amp until these are properly repaired.
-Chris
Hi Steve,
Most good technicians are very busy. This is expected.He is busy to Christmas and a trade show after but I told him I would bring them round in mid-January.
-Chris
Thanks all for tolerating my incompetence.
I feel comfortable with the service center I will be going to. I have the amps unplugged and set aside for now. Will see in mid January what the results of their service will yield and will let you all know. As for now, I am out of town for a week.
Happy holidays!
Steve
Happy holidays!
Steve
Hi all! Its been a while...recession and all.
I finally got my amps back and here is how it went.
They said the boards were originally sprayed with an adhesive coating that, after a while, became conductive. It wasn't electrolyte on the boards. They said an ultrasound would not clean this stuff, anyway. They needed to scrap it off. They also said the boards had some caps replaced at one time. As the amps were supposed to have had this done before I bought them, I am guessing the elctrolyte was cleaned off the glue, at the same time some of the caps were replaced.
Getting them home I see they will pass the Mic/Dolby set up sequence on the Sony (they failed before), but I still see they are a lot quieter than they originally were. Is it possible these issues have damaged the preamp abilities of my Sony receiver?
Unfortunatly I put them back in the cabinet without measuruing the offset. That's next.
Thanks Spind. Sorry so long for the reply!
Further tales of the Adcoms: After getting them back and with a noted improvement of the output, they still were not up to par. I brought them back to the shop to test the RMS output. Colombus Radio called and asked me to bring in whatever I was using as a preamp, a Sony STRG1000. When I arrived, Bill had a copy of the Adcom GFA 565 workshop manual and it stated the Adcoms required a preamp signal of 2.4V to obtain 300W RMS @ 8ohms. My Sony (which I have never been happy with - it won't do pass through video!) measured at .6!
Although it could be noted that I should have checked this first, and it was one of my first assumptions, I find it very interesting that throughout this process, the boards having had the caps reportedly done already, to wit the discovery of a glue sprayed on these older paper boards that becomes conductive with age and requires an old fashioned scraping to remove, showing significant improvment is something that owners of these classic amplifiers that have done their caps should be aware of and look into.
Thanks all!
Thanks all!
- Yet another Adcom GFA-565 problem
