Other channel, on the other hand, has ~200mV DC, and the pot is already in its end position. Any suggestions?
Maybe your amp has poorly matched transitors. I bought my boards about a year ago and the seller (douk audio) stopped selling them. The kit came with matched components that were all labeled and packed in individual bags.
How do you adjust zero DC on the output?
There is a 50k pot for dc adjustment
The boards I have uses only one pair of mjl1302a/mjl3281a, 4 pairs of mje15032g/mje15033g and 2n551 and 2n5401.
I see the boards you have use 2 pairs of Toshiba 5200 and 1943
I have by the way compared mine to Aleph, Zen, F5, J2 et.c.
It was some time ago, I would say a bit brighter than pass amps and imaging might be close to all but Zen maybe...
My boards are the one with all big trannies in one row and only single output devices.
I will gladly sell this project to anyone who wants. Just boards or even all of it.
Need to put time, money and enclosure on the VFET amp now
A photo can be found on the first page of this thread.
Planning to with the updated board, did some one tried out?
If so please let me know so that it would help me.
Out put power is stated as 100W @ 8ohms in one site and for the same mentioned as 140W @8 ohms, which one is correct and how to achieve 140w @8ohms with same board what is the recommended DC input voltage?
Best Regards
You can buy that damned think - no need for DIY
DARTZEEL NHB-18NS PREAMPLIFIER WITH NHB-108B POWER AMPLIFIER (INC MC PHONOSTAGE) | eBay
Douk Audio Non-NFB Amplifying Circuit 150W 2.0 Channel Power Amplifier DIY Kit | eBaywhat is the recommended DC input voltage?
dual 35-40vac 300-500w transformer
or the one that they do it for you:You can buy that damned think - no need for DIY
Douk Audio Professional Hi-End Non-NFB Power Amplifier Stereo HiFi Amp 250W@4ohm
I have both the Douk audio and the V0.2 boards from aliexpress.
They are both exactly the same
Both exactly same in case of performance or the design?
- Dartzeel amp schematic - build this?
