dartzeel amp schematic..build this?
Old 13th March 2019, 05:32 PM   #241
domenico80 is offline domenico80  Italy
if I'm not mistaken it's a final amp with a pair of power amps per channel.
if I'm not mistaken, power amplifiers placed under the printout.
If you feel like trying, if they are mosfets, to put two pairs per channel: it changes a lot
it also changes from two pairs to four pairs per channel, but not as from 1 to 2
example, from 4 to 8, in my opinion, it is hardly heard, at least in a scheme like the one I posted
Old 14th March 2019, 01:54 AM   #242
Walkalone is offline Walkalone  Viet Nam
You are correct,
Using only one pair LMOS as output, sounding is relatively too soft, insipid. But this matter happened with Hitachi/Renesas, Exicon's single die devices.
I also used one pair, but it is dual die devices ECW20N20/ECW20P20. It's two single die device integrated inside package TO-264. That problem is fixed.
Regard,
Cuong Nguyen
Old 15th March 2019, 10:59 AM   #243
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by gaborbela View Post
Someone re-engineered the 458 and he came up with this.
Taking into account the particular method of reverse engineering we can expect a reasonable interpretation, but not a true facsimile. Still, it appears pretty convincing.
There is one particular area which baffles me. The +-5v separate supply for the CCS and the offset compensation. Apparently the sole reason for this additional PS is to reduce the power-on thump. Seems very unlikely the original was designed this way; a separate PS for the entire front end (VAS in this case) would make much more sense.
Any thoughts?
Old 15th March 2019, 01:22 PM   #244
fake news ?
Old 15th March 2019, 03:05 PM   #245
analog_sa's Avatar
That is also a possibility
dartzeel amp schematic..build this?Hide this!Advertise here!
I want to build this amp need schematic LP 2002 Jonny Hotnuts Car Audio 10 7th June 2008 01:15 AM
DarTZeel, Stereophile's 2005 Amplification Component... Ultima Thule Solid State 110 30th December 2005 07:53 AM
the dartZeel NHB108 amp pmkap Solid State 7 5th September 2003 08:20 PM
darTZeel NHB-108 model one deletraz Solid State 0 5th September 2003 06:34 PM
Copyright ©1999-2019 diyAudio
