Dartzeel amp schematic - build this?
Old 19th September 2020, 06:19 PM   #1641
selfy is offline selfy  Bulgaria
selfy's Avatar
I already tried to remove the diodes in simulation. That is why I asked if someone tried the effect in the real world
"Music is enough for a lifetime, but a lifetime is not enough for music" Rachmaninoff
Old 19th September 2020, 07:27 PM   #1642
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by marigno View Post
So we expect some distortion from them.
It doesn't seem to be quite so simple. Especially with such low resistors values.
Selfy, please double check your sims, as mine shows the opposite: much lower distortion with the diodes in place.
My faith in the sim is limited as my physical amps generally seem to distort less than what the sim predicts.
Now i have little choice but to actually measure the distortion without the diodes
Old 19th September 2020, 08:01 PM   #1643
marigno is offline marigno  Italy
It could be that there is some limitation coming from the CCS together with the diode/absence of diode. Without diode the output impedance seems to be higher so higher is the distortion.
To drill a bit you should try, if possible, to lower the R and try again down to 0Ohm.
Quod tu cum audis, deos rogabis, totum ut te faciant aurem (feat. Catullo).
Old 19th September 2020, 08:25 PM   #1644
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
In this case you have output bjts switching when in class b and diodes switching when base pulls enough current trough base resistors, so in theory it makes things worse as I understand, but maybe I'm missing something... So value of the base resistors is critical for intended operation, and I'd like to know how is that determined?
I use Micro Cap for simulation and when I find time I'll give a look what is "the catch" if there is any..
Btw are values of resistors same as in the original circuit?
As Below So Above
Old 19th September 2020, 08:32 PM   #1645
analog_sa's Avatar
Indeed they are.
Old 19th September 2020, 09:41 PM   #1646
My WHA-217 does not switch on output pairs but does on their driving diode.
But let's forget about heavy mods like mine, too many variables and understanding each other would be difficult. Let's also forget about accessories like midpoint keepers and so on. We will find a solution for everything at the right time.
If you like, let's go to the core and keep it simple.
Have the original schema as a base, I reposted here, that is the mother of all variants.
Since you (plural YOU) have the knowledge of simming, there are a lot of "core" aspects you could investigate on this original. One of them is about the heavy (for the signal) L-pad R7/R5 (R8/R6). But we are now dealing with the way to drive the final stage across the diode. So let's point our focus on this first goal: presence/absence of the diode and varying the resistor value.
Would you?
Old 19th September 2020, 11:43 PM   #1647
analog_sa's Avatar
There is no easy way to automate this in LTspice, so each instance has to be run separately and cannot be displayed graphically.
The base resistor value and the bias current are shown on top. 20W/4ohms
1ohm, 724mA
no diodes 0.09637%
diodes 0.09637%
10ohm, 387mA
no diodes 0.2534%
diodes 0.26338%
20ohm, 268mA
no diodes 0.3891%
diodes 0.3451%
27ohm, 224mA
no diodes 0.474%
diodes 0.3%
30ohm, 210mA
no diodes 0.5092%
diodes 0.3798%
It looks quite fascinating. 27ohm seems to be a sweet spot where the diodes become really helpful.
Selfy is also right: at lower resistor values/higher currents the diodes appear detrimental to distortion.
Could this be a distortion compensation mechanism where use is made of the diode non linearity?
In a real amp the optimal value is perhaps different and may be worth the effort to adjust.
Old 20th September 2020, 03:03 AM   #1648
20W/4Ohm___I=2240mA___TR hfe avg=90
IF ABSENCE OF DIODE
Idle mA___R mA___R Ohm____R mV
____724___32.9_______1____32.9 too far from diode threshold, diode remains off;
____387___29.2______10___291.9 far from diode threshold, diode remains off;
____268___27.9______20___557.3 close to diode threshold, diode would start switching sometimes;
____224___27.4______27___739.2 close to diode threshold, diode would switch;
____210___27.2______30___816.7 over diode threshold, diode would switch hardly.
At different output power/impedance everything changes.
I have to think about the meaning of all this.
It was hard to align the text!
Old 20th September 2020, 03:14 AM   #1649
Originally Posted by analog_sa View Post
And here is Damir's circuit as a possible replacement for the diamond.
Would you like to simulate Damir's ciruit with Q10's collector moved to B- and Q12's collector moved to B+?
Old 20th September 2020, 05:28 AM   #1650
Collectors moved to rails gives little slower circuit (inpit bkts are not bootstraped). With collectors on emitters, like in schematic you could use lower power, higher ft bjts...
As Below So Above
Dartzeel amp schematic - build this?Hide this!Advertise here!
DarTZeel, Stereophile's 2005 Amplification Component... Ultima Thule Solid State 111 21st December 2019 09:01 AM
I want to build this amp need schematic LP 2002 Jonny Hotnuts Car Audio 10 7th June 2008 01:15 AM
the dartZeel NHB108 amp pmkap Solid State 7 5th September 2003 08:20 PM
darTZeel NHB-108 model one deletraz Solid State 0 5th September 2003 06:34 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
