The Frugalamp by OS
The Frugalamp by OS
Old 22nd November 2008, 03:48 AM   #141
andy_c is offline andy_c  United States
Banned
Looking much more like a single pole response now. Good stuff. Try right-clicking on the V(b)/V(a) expression at the top of the graph, and putting a minus sign in front of it in the expression editor dialog. Then click OK. Left-click on the -V(b)/V(a) expression. That will activate the measurement cursor. Move it until you find the frequency at which the magnitude is as close to 0 dB as possible. What is this frequency? And what is the phase shift at that frequency?
Old 22nd November 2008, 03:53 AM   #142
ostripper is offline ostripper  United States
ostripper's Avatar
Andy, freq. is 344khz , and phase is -96dB.
Old 22nd November 2008, 03:55 AM   #143
lineup is offline lineup  Sweden
lineup's Avatar
ostripper
just one little detail: R3 10k in long tail pair
BC546 can take 60 Volt, so you need no such resistor.
It does not do any good.
Probably does things a bit worse
As Douglas Self tells us:
Originally posted by DouglasSelf
http://www.siliconchip.com.au/cms/A_110797/article.html
is a copy of the Blameless design,
carefully including a mistake I made.
(putting a resistor in the input tail - bad move)
lineup
Old 22nd November 2008, 04:01 AM   #144
ostripper's Avatar
Line up, there are 50 volts across R3, even when I reduce it to
8.2 k I get 4+ma in each differential , so removing it would
fry my LTP.!!!
I see your point, as you would have to modify the CCS to
take the place of R3...
Old 22nd November 2008, 04:06 AM   #145
Banned
Looks like the amp is a bit overcompensated.
Try finding the frequency at which the phase shift of the loop gain is -100 deg. This will be a frequency larger than 344 kHz. That's what you want to be your new unity loop gain frequency. To increase the unity loop gain frequency, you can decrease the input stage emitter degeneration. Try decreasing it in the same ratio that you're increasing the unity loop gain frequency. That is, if the new unity loop gain frequency is e.g. 500 kHz, the new input stage emitter degeneration resistor should be 344/500 times the old one. Replace 500 by the actual frequency in kHz at which the phase of the loop gain is -100 deg.
Old 22nd November 2008, 04:09 AM   #146
lineup's Avatar
50 volts, so what
the ccs transistor (BC546) can take 60 volt,
so taking 50 volts from R3 and let BC546 have it
is no problem
And if you need higher, you can use 2N5551 (160 Volt C-E) or some other
for constant current source transistor
lineup
Old 22nd November 2008, 04:12 AM   #147
lineup's Avatar
To change CCS current in input you use R8, 220 Ohm
Increase R8 will lower current in LTP
Decrease R8 will give higher current in LTP
get away with R3, as D.Self says: it was a mistake (bad move)
lineup
Old 22nd November 2008, 04:19 AM   #148
ostripper's Avatar
Hey, this is fun...At unity gain freq. is 536khz and phase is
EXACTLY -100.39db.. good guess.
Old 22nd November 2008, 04:23 AM   #149
Banned
I'm confused. At 536 kHz, the gain should be less than 0 dB right? Which means you'd like to decrease the emitter resistors in the input stage to get it back to 0 dB there. Or did you already tweak the input stage emitter degeneration?
Old 22nd November 2008, 04:32 AM   #150
ostripper's Avatar
By lineup - To change CCS current in input you use R8, 220 Ohm
Mr. self has said other things ,too but do we always listen to him?? he said a balanced VAS was too much trouble, but I'm
not listening.
One thing at a time. your idea is good but the load on my LPT
is in the uA's (EF'ed VAS's)balanced as well. With a different amp, like frugal 1, I will try this.
BTW , I figured out how to import .models and made my own
LTspice libraries (custom)..thanks
OS
The Frugalamp by OSHide this!Advertise here!
Copyright ©1999-2019 diyAudio
