STEREO FET BUFFER  on ebay
Old 29th December 2008, 05:03 PM   #11
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: 2sc2240 & 2sa970
Originally posted by rlim
What are the bipolars there for? Aren't the fets followers?
cascodes ;
that way fets are working in constant voltage mode
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 29th December 2008, 05:37 PM   #12
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
can i replace the opamps in my system with these ? i have 2 opamps per channel..first one comes after the volume control then the second one constitutes the baxindall tone control circuit, will it be really worth all the trouble i use NE5532 opamps.
SivanandBalan
Old 9th April 2009, 02:42 AM   #13
feathed is offline feathed  United States
Will this e-bay buffer work with +/- 12V? or +/- 18V?
Old 9th April 2009, 03:22 AM   #14
fab is offline fab  Canada
fab's Avatar
Default Re: Re: Re: Re: STEREO FET BUFFER on ebay
Originally posted by lineup
In UK the seller of this stuff at ebay is tubeshunter
http://stores.ebay.co.uk/tubeshunter
Good luck if you want to deal with this "tubeshunter". I have received half the part listed in one of its kits and after 2 months he does not even bother to respond to me anymore after using all kind of excuses. Finally I never got the missing parts and this seller is out of my list forever!
My stuff USSA, FSSA: https://fabaudio.online
Old 9th April 2009, 08:41 AM   #15
DorinD is offline DorinD  Romania
DorinD's Avatar
Default Re: Re: 2sc2240 & 2sa970
Originally posted by Zen Mod
cascodes ;
Sorry, I'm not understanding yet. Without bipolars those FETs are also in the same "constant voltage mode" as drains are connected to a voltage source, or not?!
Personaly, I'm thinking that this is not a cascode at all because is not used as intended. If you make good decoupling of the V+/- sources with some good capacitors, bipolars could be taken out with no problem.
Thanks.
Old 9th April 2009, 01:57 PM   #16
h_a is offline h_a  Europe
h_a's Avatar
Yeah, a little strange part choices; low noise bipolars for cascode, but no low noise jfets. I see it the same as Dorin, the cascode is of little use here. Also it seems - although the point in the schematic is missing - that the cascode is output-modulated for which I also don't see much reason here.
Nevertheless I don't see a reason why the buffer shouldn't perform well.
Have fun, Hannes
High Octane phono preamp Wiki
Old 2nd July 2010, 12:38 AM   #17
idlehands is offline idlehands  United Kingdom
I found was a huge benefit of adding caps from the power rails to ground on the board itself, in this case 100uf, 10uf and 0.1uf. Without the caps it was pretty poor.
Old 20th January 2012, 04:30 PM   #18
colin.hepburn2 is offline colin.hepburn2  Scotland
colin.hepburn2's Avatar
Hi All
Well just got the buffer today from china on a slow boat again I have been sent an updated version in that the board is now double sided now it seems to me that the screen print is wrong in the power supply pin ID from left to right -15volt 0v +15volts which seems the wrong way round plus the + 15v is connected to 0V
i have emailed the seller on this but he denies this and said the board is same as the old one and refuses the help this image is the old board the one I was expecting to get
And this is the new double sided board
And the underside of new board you can see that the -15volt connects both channels and the +15volt connects to ground
Here is the old schematic
can anyone help me get the supply wiring correct thanks
Colin
The Blues Man
Old 20th January 2012, 07:56 PM   #19
Good Luck! The SOB still owes me money!
Old 20th January 2012, 08:08 PM   #20
Yep thatís the second time this seller has refused to help after he has been paid second change an all that he wonít get my money again thatís for sure
Colin
The Blues Man
STEREO FET BUFFER  on ebayHide this!Advertise here!
Phono stage for 2 7F7s (stereo) plus buffer? GordonW Tubes / Valves 7 21st August 2008 04:23 PM
Pre-Amp / Buffer on Ebay poynton Solid State 1 22nd June 2008 01:40 PM
$5 cheap headphone amp / stereo buffer board raidfibre Group Buys 8 19th November 2007 06:25 PM
Copyright ©1999-2019 diyAudio
