My MOSFET amplifier designed for music.
Old 24th May 2019, 03:07 PM   #891
bandol83 is offline bandol83  France
My MOSFET amplifier made for music designed by Mooly is at Philippe home for the final integration in the enclosure, he is living not very far from me, also in the south of France, close to the little town of Bandol well known for the wine produced here I am lucky that Philippe is very smart in mechanical job because I am very bad for that Before I meet him (thanks to Internet Audio forums...) I had plenty of electronic boards assembled and working but not packaged !
Finally Philippe who has also made the final integration for my Quasi will keep the two small CRC power supply modules for his own Quasi project, therefor I had the opportunity to redesign a slightly larger CRC board for the Mooly amplifier since it use a bigger enclosure (see previous post). The new board will have the same height than the Mooly amplifier board designed by Prasi and will fit nicely close to it on the heatsink. With the bigger PCB I was able to put 30 mm diameter capacitor instead of 25 mm, it is possible to use 10'000 uF 50 V or 6'800 uF 63 V (what I am using now) which should be enough for most amplifiers...
Since the Mooly amplifier is no more here, I tested the power supply with an other small amplifier that I have designed to use some LM4702 (now obsolete) and Sanken STD03 that I had in stock. I have designed a first version 10 years ago but I made several mistakes and the ground was not well routed and I had some noise
This version is much better, I have no noise at all and the sound is very good, may be not as transparent and clear as the Quasi or the Mooly but it is a very simple and very compact amplifier to build (it is a stereo board !). If someone is interested and have some LM4702 in stock, it is possible to get the board from PCBWay because I share the design : LM4702 sanken amplifier - Share Project - PCBWay
When the Mooly amplifier will be finished, I will put the photos here For information I have just ordered 12 Renesas 2SJ162 and 12 2SK1058 from Reichelt because these Lateral MOSFET are still available from them
Marc
Old 25th May 2019, 12:57 AM   #892
Vrystaat is offline Vrystaat  South Africa
Well done !!
Jan
Old 25th May 2019, 10:37 AM   #893
AKSA is offline AKSA  Australia
Hats off, Marc!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 2nd June 2019, 03:34 PM   #894
AMPMAN is offline AMPMAN
Default mooly amp
Hi mooly can you please show me how to conert your amp to balanced input regards ampman
RW
Old 2nd June 2019, 07:45 PM   #895
Mooly's Avatar
Its not suitable for balanced operation I'm afraid as that really only applies to differential input stages that have similar characteristics between the inverting and non inverting inputs.
The emitter of the input transistor is the inverting input, however the single ended nature of the input stage means its not suitable to be used in a balanced configuration, not least because the DC conditions are always different between the two inputs.
Old 12th June 2019, 02:37 PM   #896
UltimateX86 is offline UltimateX86  France
HI,
Do you know the Q5 dissipation on idle and max output voltage ?
(edit) i found the asc : 268mW idle and 436mW pic with 28V output
it is not to high for a TO92 ?
thanks
I do not sell anything, I'm just trying to build a www.circlotron.audio
Old 12th June 2019, 05:44 PM   #897
Mooly's Avatar
The dissipation is well within limits. This shows the 2N5551 data of power dissipation vs ambient temperature.
Old 13th June 2019, 07:51 AM   #898
Thank you mooly,
in fact if I asked the question is because I would also used TO92 in VAS (BC560) and forumers warned me about the risk of reliability because of them while I had 200mW in idle and 280mW maximum
if you have no problem, I should not have any
Old 11th July 2019, 08:23 PM   #899
brian92fs is online now brian92fs  United States
Originally Posted by nfsgame View Post
Is there any possibility of getting the gerber files for this version with four outputs? Just for home-use of course!
Are Prasi's gerber files for the slimmer width PCB posted somewhere? I couldn't find them in the thread.
Old 1st August 2019, 05:58 PM   #900
Default mooly amp
Hi mooly, on my first board there is a slight wiggle at the top and bottom of the sine wave which I presume is distortion. Output voltage is good but I can't control the IQ. Second board I can't control the IQ and that is to say it goes way too high whereas the first board I can't increase it at all.
RW
My MOSFET amplifier designed for music.Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
