Hello
I have 2 Dynaudio Contour 2 loudspeakers and I simulated their crossover with VituixCad software (very well done, congratulations!). I don't understand why if I connect the 3 speakers with the same phase (as all theories say for a 1st order filter) a deep depression at 1400hz is highlighted !!! If I invert the polarity of the mid-range the response improves! See attached diagram.
Thank you
Thank you
Dynaudio Contour improvement
Name of this thread must be changed to e.g. Dynaudio Contour improvement. VituixCAD thread already exists and must be kept individual.
Driver measurements are not taken according instructions so not much hope for improvement.
Electrically 1st order XO produces usually 2nd order acoustical slopes due to natural acoustical slopes of drivers so mid should be inverted in practice.
Is this truly Dynaudio Contour 2 original x/o schematic?
Inductor dcr values are probably a default software setting.
off topic: why does forum software shift two rows for just one enter click?
I always need to shift rows higher to get it like I wanted it in the first place.
Using Firefox? It is a bug in FF. If I have understood you there is a fix:
The quick fix is to edit about:config in FF
go to this line:
editor.use_div_for_default_newlines
and click on true to change it to false
- Design & Build
- Software Tools
- Dynaudio Contour Improvement
