Another WinISD question
Simulating vented boxes using different drivers I encountered the following problem: The plot "Max Power" displays a dropping max power value at lower frequencies. So I suspected max cone excursion was exceeded, but the xmax plot does not indicate this.
So my question is - what is the reason for this power limitation? I append the max power and xmax plots of eminence legend BP102 in a 50L vented box for reference.
