Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
EDA with vacuum tubes symbols
Old 29th June 2020, 11:47 AM   #1
dl1964 is offline dl1964  United States
Default EDA with vacuum tubes symbols
Can anyone recommend a simple Open Source Circuit Design Software with a library that has vacuum tubes symbols?
TIA,
/DL
Old 29th June 2020, 02:29 PM   #2
Redbeard is offline Redbeard  United Kingdom
Hi dl1964,
Is it specifically open-source you're after ? To tinker with the code ? Or would free circuit design software do ?
i used gEDA for a while (free, open-source, runs under Linux), then PSpice for a few years (very NOT free, certainly not open-source). Neither have thermionic valve symbols built in, you have to generate them yourself.
However, i have recently started using LTspice from Analogue Devices. It's free (but not open-source) and many users here find it useful. Valve symbols are (i think) included in the install, triodes, tetrodes and pentodes, but are also available on t'internet.
What do you want to use this EDA softwear for ? Just drawing circuit diagrams or simulating circuits ?
EDA is a right rigmarole, i'm a pen-and-paper design guy. All EDA (Electronic Design Automation) softwear is a right faff. There's a lot of mucking about to do.
So what are you up to ? What aspect of EDA do you need ?
All the best,
Neil xx.
Old 29th June 2020, 02:45 PM   #3
Hi Neil,
Thank you so much! I've downloaded LTspice yesterday, and was going to install it later today, not realizing it has some tube symbols already in the install. If that's the case, I'm golden!
I'm just looking for a neat way for keeping circuits drawing documented, and my hand written diagrams are far from neat... that's all, nothing fancy (well, not at this point anyway).
Thx again!
/DL
Old 29th June 2020, 02:52 PM   #4
Mooly's Avatar
LT has valve symbols located under 'Misc' in the component selector.
Click the arrowed symbol to get back to the top directory.
Click my sig line to see how to use LT
...or even easier:
Old 29th June 2020, 03:17 PM   #5
Cheers Mooly,
Hi dl1964,
For proper neat drawings, good for publishing but of no use whatsoever in EDA i use Macromedia Freehand 11. It's free because Adobe preferred to support their own softwear (Illustrator) and discontinued Freehand.
i've used Freehand (Aldus, Macromedia, then Aldus) since 1990 and it is the very best.
Xx.
Old 29th June 2020, 07:48 PM   #6
This is fantastic!
Thx much!
/DL
Old 29th June 2020, 07:51 PM   #7
As did I back in the day, for network diagrams. Then I decided I sucked at this and started using Visio...
Thx much!
/DL
Old 5th July 2020, 01:34 PM   #8
davidsrsb is offline davidsrsb  Malaysia
KiCad has a variety of valve symbols if you want to actually draw circuit diagrams
Old 5th July 2020, 02:23 PM   #9
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
i use ltspice for simulating valve circuits.
2020 versions of PCBCAD51, PCBCAD360 and PCBCAD720 out now >>> https://www.murtonpikesystems.co.uk
EDA with vacuum tubes symbolsHide this!Advertise here!
vacuum tubes soretooth Swap Meet 5 5th June 2015 08:29 AM
vacuum tubes tubesdep Vendor's Bazaar 1 20th April 2013 08:43 AM
Vacuum Tubes siliconray Siliconray Online Electronics Store 2 11th October 2011 11:29 PM
Vacuum tubes, vacuum capacitors and vacuum relays GREENSTONE USA Vendor's Bazaar 0 19th August 2011 03:38 PM
DIY vacuum tubes! sss Tubes / Valves 1 17th January 2008 12:49 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
