Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
AKABAK 3
AKABAK 3
Thread Tools
Old 18th September 2020, 11:29 PM   #71
xrk971 is offline xrk971  United States
Got Foam?
Sin Bin
AKABAK 3
Originally Posted by xrk971 View Post
It just so happens that I have a 3D model of the K15. It has been scaled by 0.44x but someone should be able to apply global scaling to get it back to 1.0x full size. Here is the STL file. The render of the wireframe looks like this:
This one has skinny little slot vents that I think will suffer compression losses and add distortion, but the basic shape is there:
Go knock yourselves out with Akabak3 or ABEC3!
I have a model of it in Akabak 1 that works pretty well for freq below 500hz:
A Speaker that Kicks Butt in Large Spaces
Someone requested that the 3D model be provided in STEP file format.
Old 24th September 2020, 09:45 AM   #72
kipman725 is offline kipman725  United Kingdom
Overly Enthusiastic
kipman725's Avatar
AKABAK 3 Send a message via MSN to kipman725
I had a go at this K15 simulation but my results are not making much sense, just getting a response like a resonant pipe. Any ideas? (simulation files attached).
Old 24th September 2020, 10:36 AM   #73
Got Foam?
Sin Bin
AKABAK 3
This was a 0.44x scaled 3D model, did you upscale it by2.27x to get back to 1.0x scale? Even at 0.44x scale the response should be different. I don't use Akabak3 so cannot check your files. What driver did you use?
Here is what I get with my model for an EV SP15A driver at 2.93m and 1m:
AKABAK 3-k15v3e-evsp15a-freq-2-83v-1m-png
Here is predicted impedance:
AKABAK 3-k15v3e-evsp15a-imped-png
Predicted cone excursion for 2.83v:
AKABAK 3-k15v3e-evsp15a-displ-png
From the impedance and displacement curves, we can see that the box tuning of the K15 with the EV S15A driver is about 45Hz.
T/S params:
Code:
Def_Driver  'EV SP15A' | 103 dB Qts 0.45, 5.1 mm xmax
  SD=855cm2   |Piston
  fs=40Hz
  Qms=5.0
  Qes=0.49
  Re=6.2ohm
  Vas=280L
What does your predicted impedance look like, that is usually a good indicator if your model is working well.
Old 26th September 2020, 06:43 PM   #74
kaameelis is offline kaameelis  Estonia
I tested file. I find Interfaces normals where in wrong direction. After change I get next result.
I understand scaling to original size is made already in mesh file.
I get warning when opening file that it was made with newer version of AKABAK and some feature may be lost. I had 3.1.2 b59 AKABAK, as I understand latest available. With what version was the K15_attempt2 made? After opening frequency range was 10-2kHz, not as you original 10-500Hz. I also notices that in Observation was missing Fileds1 and Polar1
Old 27th September 2020, 08:08 AM   #75
freddi is offline freddi  United States
freddi's Avatar
FWIW, for a reference vs simulations
here's an outdoor measurement, with mic laying on the ground and 2M away from a Karlson K15 loaded with the now defunct - small motor Eminence Beta15CX speaker. https://www.parts-express.com/pedocs...ions-44613.pdf
Old 28th September 2020, 03:02 AM   #76
freddi's Avatar
K15 nominally tunes in the 45Hz region. Deletion of the front "shelf" and its associated port boundary may move that up a couple of Hz. What T-S parameters were used for the simulation?
I think the front shelf board did some correction of the first dip. Making the front chamber a few inches less deep would probably make better graph and allow deletion of that front deflecting board.
I'm interested in the 0.44 scale version as could make a fun sub -sat system which could play quite loud.
Old 28th September 2020, 12:51 PM   #77
Overly Enthusiastic
kipman725's Avatar
Thanks for your efforts efforts kaameelis and xrk971. I did work out that the normals where the wrong way round on the interfaces and got a peaky result like kaameelis did, so I didn't post as it still looked wrong. The mesh is scaled back to normal K15 size and the driver T/S are the Emminance Kappa Pro 15A. I'm not super familer with Karlson designs, what is the front shelf?
Old 29th September 2020, 12:50 AM   #78
freddi's Avatar
the front part of the shelf was gapped about 9cm from the inside of the aperture. XRK971's model IIRC deletes that part. Karlson did not use it in any of the smaller models. It may have been used in Karlson's 18 inch console and was used by Cetec-Gauss in their 5181 K18 cabinet.
Old 29th September 2020, 09:30 PM   #79
I find one parameter wrong in K15_attempt2 simulation file, VC inductance was 100 times bigger than is for Kappa Pro 15A.
Result seems better now, relatively close to measured.
Old 30th September 2020, 06:55 AM   #80
freddi's Avatar
hi kaameelis - That is pretty impressive !. I wonder if the 0.44 scale version looks similar only moved up in frequency and also what happens with the horizontal polars for the 0.44X case.
AKABAK 3Hide this!Advertise here!
Thread Tools
Akabak Simulator pinkmouse Multi-Way 85 6th November 2020 09:38 PM
LT in Akabak? TundraLTD Subwoofers 0 5th January 2014 08:55 PM
Akabak and Hornresp lightspeed Software Tools 3 11th March 2012 03:41 AM
Akabak & stuffing Henkjan Subwoofers 15 3rd December 2010 11:44 PM
AkAbak Info pighead Multi-Way 0 5th July 2009 08:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
