Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
AKABAK 3
AKABAK 3
Old 20th October 2020, 10:25 PM   #111
freddi is offline freddi  United States
freddi's Avatar
Very cool - - - tuning looks right on a 4 string bass guitar or string bass "low E" string. Also, there is substantial excursion reduction where the front chamber resonates so would guess modulation distortion to measure low over a certain range of two tone combinations.
Old 23rd October 2020, 05:07 PM   #112
freddi's Avatar
@kaameelis
Regarding the Karlson115 1.2X simulation, is there an easy way to shut off the vent's contribution and see response with the back chamber sealed? - - Or does a new model have to created?
Old 23rd October 2020, 08:15 PM   #113
kaameelis is offline kaameelis  Estonia
I was easy, I redefined interface between rear and front to wall.
You probably understand what is what.
Old 23rd October 2020, 11:23 PM   #114
freddi's Avatar
That is really cool !.
I used to have a graph of 115BK with its port blocked vs open but IIRC, that was smoothed to 1/6 octave.
Here's something to examine as a "tweeter":
Take the standard "Karlson115" which is for a 15 inch speaker and scale it 0.2X for a 3 inch speaker. (3FE22-4 spec below) Block the port. Then see if its usable to say 1KHz or lower crossover without a terrible dip. Also look at the response off horizontal axis vs on axis at a distance of 1 or 2M.
Does Akabak3 assume pure piston behavior for such simulations?
Def_Driver ‘3FE22-4’ | Faital Pro 3 inch fullrange driver 1.73mm xmax
Sd=33cm2
Fs=110Hz
Mms=2.4g
Qms=3.57
Qes=0.4
Re=3.3ohm
Le=0.10mH
Vas=1.3L
  Reply to this post
AKABAK 3Hide this!Advertise here!
Akabak Simulator pinkmouse Multi-Way 80 3rd March 2020 01:32 PM
LT in Akabak? TundraLTD Subwoofers 0 5th January 2014 07:55 PM
Akabak and Hornresp lightspeed Software Tools 3 11th March 2012 01:41 AM
Akabak & stuffing Henkjan Subwoofers 15 3rd December 2010 10:44 PM
AkAbak Info pighead Multi-Way 0 5th July 2009 07:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
