Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
LIMP and Focusrite Scarlet 2i2
Old 7th April 2020, 03:33 PM   #1
rajestanna is offline rajestanna
Default LIMP and Focusrite Scarlet 2i2
Hello.
I am trying to use LIMP with Focusrite Scarlet 2i2 ist Gen. The DUT is driven through an Amplifier
Please help me with the following queries:
(1) The Scarlet has mic , Line and Instrument level inputs.
Line In: input impedance is 10K and noise in presence of signal is -104dBu at min. Gain
Instrument In: Input impedance is 1Meg and noise in presence of signal is -87dBu at min. gain
Would it be better to use Instrument in or Line In and why?
(2) Limp manual suggests using reference resistor of 10 to 27 ohms. Professional systems use low value current Sense resistors. What would be the problem if I use a 0.47ohm or 0.22 ohm for the reference resistor. ( I am using an Amplifier to drive the DUT)
Thanks and regards
Old 7th April 2020, 07:01 PM   #2
celef is offline celef
if i were you i would test different restor values and compare the results, i would also try both inputs and see which one gives best results. i would also try different test levels, but be sure to protect the input from excessive levels
i would also try measure impedance using the soundcard headphone output
Old 8th April 2020, 09:15 PM   #3
Mark Tillotson is offline Mark Tillotson
Instrument is for electric guitars which can't drive 10k, use line input, much cleaner and should have a flat response,
which the instrument input might not.
The sense resistor should be close to the impedance being measured, due to the limited
connection setup (not a differential measurement of the shunt). Use ~10 ohms for a speaker, ~50 for a headphone.
LIMP and Focusrite Scarlet 2i2Hide this!Advertise here!
How to kill a Focustire Scarlet 2i2 Eva Digital Line Level 14 4th February 2020 09:41 AM
Focusrite Scarlett 2i2 Gen 1 jan.didden Swap Meet 0 21st December 2018 12:50 PM
Focusrite - Two mics.? KowalskiCZK Equipment & Tools 1 13th August 2016 10:58 AM
Behringer and Focusrite ashok Equipment & Tools 19 12th April 2015 09:07 AM
LIMP bug? crazyhub Software Tools 2 16th September 2009 04:43 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
