Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
TINA spice simulation gives floating warnings
Old 6th November 2019, 06:15 PM   #41
inkl is offline inkl  Russian Federation
ok, I added R5=47 Ohm and now I have the following:
gain:
so why is this R5 is so critical?
Well, I just started reading about op amps...
Old 6th November 2019, 06:19 PM   #42
audio_tony is offline audio_tony  United Kingdom
Send a message via MSN to audio_tony
Briefly;
R5 will isolate the opamp from a capacitive load, and prevent oscillation.
Here is a very detailed explanation.
Old 6th November 2019, 06:27 PM   #43
I just found out that if I set the voltage back to 3,3V I get that weird gain curve again. And it stays the same no matter if there is R5 or not. But increasing VCC to 5V gets back things to normal...
Old 6th November 2019, 06:31 PM   #44
That's because the supply voltage is too low for the required gain.
By the way, the LT1215 is not a good choice for your application, it looks to have a high noise figure.
Try using an NE5532 for your sims because once that works reliably you can then try alternate OPAMPS.
Old 7th November 2019, 08:38 PM   #45
ok, I made another one, from Project 93:
But here's what I get in the diagram:
I don't get what it means? Also, I'm not sure I put that zener diode right. Can you please let me know what's wrong with it? The simulation seems to be correct...
Old 7th November 2019, 08:55 PM   #46
Setup some test points around the circuit and do a DC simulation, take a screenshot and post it here.
It's highly unlikely this circuit will offer better performance and gain than an OPAMP though.
TINA spice simulation gives floating warningsHide this!Advertise here!
TINA-TI Tube Simulation windwood Software Tools 14 18th May 2015 04:20 PM
LM4702 simulation in TINA danny92 Software Tools 6 16th April 2013 09:54 PM
LM4702 simulation in TINA danny92 Chip Amps 0 13th April 2013 05:37 PM
How to get these spice models in to TINA TI? rhythmsandy Solid State 0 18th December 2012 07:34 PM
Simulation Models for OPA827 and TINA-TI stef1777 Software Tools 8 13th March 2008 05:56 AM
Copyright ©1999-2019 diyAudio
