Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
LtSpice missing components error?
Old 22nd October 2019, 10:18 AM   #11
Ludus Tonalis is offline Ludus Tonalis  Europe
Is there any reason you are not apparently using the manufacturer's website (you mention mirrors)? I recommend you download the correct files for a fresh install from LTspice | Design Center | Analog Devices
If this doesn't work, and if no one here comes up with a solution, go to the LTspice users' group. It is in the process of being moved from Yahoo to LTspice@groups.io | Home, as Yahoo is closing down all groups later this year.
Old 22nd October 2019, 11:12 AM   #12
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Did you try what was suggested before, start a new schematic, then select and place those symbols?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit
Old 22nd October 2019, 03:28 PM   #13
FriedMule is offline FriedMule  Denmark
Jan
Hi and yes, sorry, I have tried to start all over and right after installation, I did select new and did place components, the only one who didn't appear was the three types in that error, but it do not write any error unless I load a schematic.
Old 22nd October 2019, 03:40 PM   #14
Thanks for the links. I did find out that this was the mirror I used, so... strange!
Do any of you have a working version I could try to download?
In the meantime will I do as you sugested and ask in that forum. :-)
Old 22nd October 2019, 05:40 PM   #15
edbarx is online now edbarx  Malta
Mine is over a year old as I am on Linux. I can only use 64 bit Windows executables since 32 bit executables do not work and LTSpice's installer is 32 bit.
My version is: XVII (x64).
Thanks for helping me design my first amplifier.
Old 22nd October 2019, 05:45 PM   #16
That would be perfect, a 64bit windows version!
LtSpice missing components error?Hide this!Advertise here!
Ltspice error gmant123 Software Tools 3 22nd October 2019 04:51 AM
CPA200 - LTspice missing nodes error janusz Solid State 10 2nd January 2019 08:49 AM
LTSpice Error? Hans Polak Software Tools 18 1st August 2016 07:15 PM
LTSpice Error Log THD values macplauder Software Tools 3 12th February 2015 08:21 PM
Missing components skruerselv Tubes / Valves 19 7th July 2010 12:05 AM
Copyright ©1999-2019 diyAudio
