Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
Thread Tools |
#41 |
Thank you for your reply!
I got it to work now, but only half-way. There seem to be two problems in my case: displaying the results, and not producing the full spectrum of the input signal. Comparing the configuration files for a case where a spectrum from the Dummy source is shown, with the one without it, I found out that in the latter case the section <DisplayCharts> is empty, i.e. it is shown as <DisplayCharts/>. When I manually insert this section into the configuration file, the graphics is shown. The screenshot attached shows the spectrum I got with my MOTU card after correcting the configuration file, but only the noise floor is shown instead of a very rich spectrum that I expect. My hunch is that the number format 32F is a problem - I don't know whether the MOTU Asio driver supports it. Since this is the only choice I get when configuring the input device, I'm not able to compare it with e.g. 24-bit resolution. I got my MOTU interface also running in the Wasapi Exclusive mode with 16-bit resolution (higher resolutions are not offered), and the result was as expected. I'll test the other native Win7 modes as well. Regards, Braca |
#42 |
To s3tup
Phase noise spectra of a 10 kHz crystal oscillator signal. Two programs for comparison. |
#43 |
Could you please refer to some keywords/description what "L*L^90" means in the 2nd program?
Most of the noise you see on SA is spectral leakage of window function. I could eliminate it to some degree in next versions, but i doubt the 2nd program uses spectral leakage compensation at all, it must be very different algorithm. Seems it multiplies the input by digitally generated sine corresponding to input signal's frequency. Technically it should produce downconverted carrier at 0Hz, and 2*F Hz. I still don't see how the spectral leakage gets eliminated, unless you turn off the windowing function and rely on coherency. If you look at 2nd program only, you have a skirt around carrier, which width is much wider than what you see on the phase noise spectra of the same program.
xdxd.io - software audio analyzer, crossover studio Last edited by s3tup; 10th September 2020 at 01:28 AM. |
#44 | ||
#45 |
Are there any news? Is the project still active?
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Is a spectrum analyzer the same as a distortion analyzer? | djn | Equipment & Tools | 21 | 11th August 2019 10:45 PM |
Any Suggestions on Free Spectrum Analyzer Software? | J.R.Freeman | Software Tools | 44 | 27th December 2018 08:38 AM |
EasyRTA - real-time spectrum analyzer software | Mister Q | Vendor's Bazaar | 16 | 22nd November 2015 04:32 AM |
Spectrum Analyzer software recommendations | head_unit | PC Based | 8 | 22nd January 2012 07:39 AM |
Oscilloscope as Spectrum Analyzer/Frequency Response Analyzer | sameerdhiman | Equipment & Tools | 18 | 9th June 2011 09:19 PM |
New To Site? | Need Help? |
