Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Help with measurements in ARTA
Old 6th September 2019, 02:41 AM   #1
itsikhefez is offline itsikhefez  United States
Default Help with measurements in ARTA
Disclaimer: I am only interested in pointers for ARTA since I've found it easier to use and I've purchased a license.
Hi, I'm interested in measuring a SE tube amp with different output tubes and load resistors. I'll be doing the tests initially on my SS amp until I'm confident with the testing process.
My setup consists of a PC with E-MU 0404 PCIe card, pmillett SC interface, Windows 7 (for driver compatibility) and ARTA.
I've done calibration and run the SPA FFT measurement and I _think_ it is working as expected.
Things I'm unsure of: 1) How to set the amp volume - I've been setting the amp volume so that the output voltage matches the input voltage, i.e, if the generated signals is -3dbFS, that is where I set the volume pot on the amp. Is this the correct way?
2) Frequency Response - I've done this both through FR1, and though IMP. In FR1, the response is almost ruler flat. When running the IMP test and marking a region, rolloff can be observed below 40hz. What is the proper way to measure this?
3) Power output - This part confuses me. With signal generator set to -3db FS, that is about 2.8V output. Due to matching the amp volume to input (as described in #1), the output is always 2.8V RMS or ~4V pk-pk. To measure output, I am doing V^2/R (R is the resistance of the dummy load). Doing it this way basically results in the same power output for anything I measure. Opening the pot all the way causes significant distortion, so what is the correct procedure here?
4) Output Z - is it possible to compute with ARTA?
Sorry for the long post, tips for any of the questions would help me greatly
Old 6th September 2019, 11:04 AM   #2
ergo is offline ergo  Estonia
Take a look at STEPS (part of ARTA package) and the Help for that. For amplifier testing the stepped sine method can be more reliable.
You can also take a look at a document I once did about ARTA calibrations. Thats for speaker measurements but perhaps helps to understand how the cal fields and values work in ARTA
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
Ergo
Old 6th September 2019, 11:47 AM   #3
voltwide is offline voltwide  Ireland
I would recommend an 30dB-attenuator between output and soundcard input. This keeps ADC modulation in the range -10 ~ -20dBFS where its own THD is at minimum.
tuby or not tuby, that is here the question!
Old 10th September 2019, 03:35 PM   #4
@ergo, thanks for the tip about STEPS.. I've used it and found the graphs useful.
Can anyone else comment on questions 1, 3 & 4 ?
Old 10th September 2019, 05:52 PM   #5
Have you tried the method from ARTa handbook
http://www.artalabs.hr/AppNotes/ARTA...%20English.pdf
And for power see the handbook for LIMP
http://www.artalabs.hr/AppNotes/STEP..._4_English.pdf
and the
3.3. Voltage- or power-related measurements with STEPS
Ergo
Help with measurements in ARTAHide this!Advertise here!
ARTA - Scaling horn mouth measurements vinylfantasy7 Software Tools 0 11th February 2019 07:12 AM
Noise measurements with Arta _ tutorial ? ginetto61 Equipment & Tools 93 25th August 2016 11:48 AM
Use L.O.C for 2-ch measurements in ARTA? NiToNi Equipment & Tools 4 27th January 2015 04:11 PM
How exactly does ARTA apply mic calibration file to measurements ? percy Multi-Way 7 18th November 2014 01:37 AM
ARTA impedance measurements - help needed!! zobsky Multi-Way 23 3rd August 2007 06:38 PM
Copyright ©1999-2019 diyAudio
