Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Howto - Distortion Measurements with REW
Thread Tools
Old 4th September 2021, 01:21 PM   #931
trobbins is offline trobbins  Australia
trobbins's Avatar
phofman, in my particular setup I use a 100:1 scope probe that works well with the 1Meg unbalanced input of the 0404USB. Modifying that input scheme to present the probe across hot and cold lines would double the probe's load impedance to 2Meg (although that shouldn't have too adverse an effect).
Old 4th September 2021, 04:11 PM   #932
wtnh is offline wtnh  United States
wtnh's Avatar
Originally Posted by audio_tony View Post
I just built a linear PSU for my test gear.
Far more convenient than batteries, and no noise issues at all.
I used an LM350 regulator and this also powers my Raspberry Pi when I'm using that for audio measurements too.
I generally find that ground loops are the biggest issue with regards to noise.
I did a few test measurements to illustrate the ground issues when using USB especially.
Nice website! Thanks for sharing.
Old 4th September 2021, 08:20 PM   #933
kozard is online now kozard
Originally Posted by wtnh View Post
The ground lift switch only has an effect when you use the TRS receptacles. If you use the XLR input pins, the switch is out of the circuit. Also, the TRS jack connects to 5532 input buffers which add a small amount of distortion. The XLR input bypasses those buffers. Unfortunately, the XLR inputs also supply phantom power for microphones, which may affect some connected devices. Presumably, turning off the 48V power switch eliminates that as a concern. A possible mod might be to eliminate the resistor which feeds the phantom power to the jack. See attached schematic.
Today I made a TRS to XLR cable and measured the E-MU 0404 USB TRS to TRS and TRS to XLR. I noticed that the 3rd harmonic was the biggest improvement when bypassing the 5532. The levels also go up a bit.
Attached in order:
  1. TRS (L Out) to TRS (B Input) -10 dBFS input level
  2. TRS (L Out) to XLR (B Input) at the same output/generator level as above.
  3. TRS (L Out) to TRS (B Input) -16 dBFS input level
  4. TRS (L Out) to XLR (B Input) at the same output/generator level as above.
So for measuring the uPC1342V I think I am set with -16 dBFS input levels, the balanced attenuator and the EBG UXP/300 load resistors.
Old 5th September 2021, 08:12 PM   #934
I have been using one of those lithium power packs intended for powering cell phones via USB. I got an adapter cable and plug to go from the USB output into the 5-volt input of the EMU (I think from Amazon). Seems to work fine and runs the EMU for several hours. No ground loops or mains hum. Since some of those battery units have buck/boost converters, I also use a small USB noise filter in between - it has a small common mode choke and some filter caps, but I am not sure it is even necessary.
I used a similar battery pack to measure the loopback on the E-MU 0404 USB with the original Creative power adapter versus battery. Loopback alone is very close to identical. However in the next post I will show the difference when measuring an amplifier.
In this post in order there are:
  1. Left TS Output to B TS Input with original Creative power adapter.
  2. Left TS Output to B TS Input with battery pack.
  3. Left TRS Output to B XLR Input with original Creative power adapter.
  4. Left TRS Output to B XLR Input with battery pack.
First two are not balanced. Last two are balanced.
Old 5th September 2021, 08:19 PM   #935
In this post I am measuring a uPC1342V based power amplifier with the E-MU 0404 USB. The degradation when using the original Creative power adapter with the 0404 is clear compared to the battery pack.
  1. E-MU 0404 USB with original Creative power adapter (wall switcher)
  2. E-MU 0404 USB with original battery pack
  3. SB0490 (Sound Blaster Live! 24-Bit USB External, USB power)
1-3 are laptop battery power, WiFi off.
In other words don't use that adapter. Use battery power if possible. Later I might try hooking up a linear regulator but the USB battery pack works well.
Old 5th September 2021, 09:01 PM   #936
wtnh's Avatar
Good progress there. Looks like your amp power supply could use more filtering; lots of 60 Hz harmonics - or there is a ground loop somewhere. Are you using a star ground inside the amp?
Old 5th September 2021, 09:53 PM   #937
The PCB for this uPC1342V amplifier has a star ground formed by a number of different traces which emerge from the thru hole for one of the two main filter capacitors. I have attached a picture showing this.
Any suggestions on improving it?
There is 2x4,700uF on the uPC1342V board and then 8x4,700uF on the rectifier board. (A picture of the bare board is attached.)
Old 5th September 2021, 11:41 PM   #938
As a comparison the attached are in the same chassis with the same wiring and same power supply.
The first is an MX50X2 and the second is a QUAD405-2 modified (gain, current source and OPA228). These measurements are made by a desktop using an E-MU 1820m microdock attached to an E-MU 1010 PCI card. (Mains powered desktop.) These measurements were done before I bought the E-MU 0404 USB and before I built the balanced attenuator.
I am mystified as to why the uPC1342V measures so badly relatively speaking (THD, 2nd harmonic).
Old 6th September 2021, 12:32 AM   #939
trobbins's Avatar
kozard, can you describe or sketch the mains power input and how it interfaces to the power supply and how that gets to your amp board, and similarly how the input signal connects to your amp board. Is there a mains protective earth connection to something? Is the power supply floating? Is the speaker output signal connected back to that pcb star point somehow? ie. there is no clarity as to what forms a hum loop and how likely there is a common noise current path between signal input and speaker output, and between those points and a loop going back through mains wiring.
Old 6th September 2021, 02:23 AM   #940
To start with here is a description of the current (partially disassembled) test setup:
Laptop is on battery power and the only connection is USB to the E-MU 0404 USB.
E-MU 0404 USB is powered by a 5V battery pack (internal 18650 cells).
Input to the amplifier comes from the E-MU left main output via a ” TS shielded cable (Gotham GAC-1) to a metal RCA plug.
The RCA plug connects to an input board connector which is not electrically connected to the chassis.
The input board connector board is connected via soldered Rapco CM Rated Installation Grade Mic Cable to the volume potentiometer board which is an Alps RH27. No electrical connection to the chassis.
The volume potentiometer board connects to the screw terminals on the pictured uPC1342V board via Rapco CM Rated Installation Grade Mic Cable. (Input connection point shown with grey arrow on attached picture.)
The power transformer is a 2x32VAC power transformer from an Onkyo power amplifier. The power transformer is currently external to the chassis and connects to the rectifier and filter board via three twisted 16 AWG Remington Industries tinned stranded copper wires. (External in an attempt to see if that reduced the power line harmonics, plus to try a different transformer.) The uPC1342V amplifier PCB has the option for the rectifier to be installed on the amplifier PCB but I did not do that. I used an external rectifier and filter board instead.
The power rectifier and filter board has 4x 120A Schottky rectifiers and 8x4700uF BC filter capacitors. (Picture of bare board attached.)
Previously the ground of the output side of the power rectifier board was connected to the chassis. I temporarily removed that as an experiment. Current (attached) results are with that ground removed temporarily. Later it will be attached again, perhaps with a 25A bridge, 10 Ohm and 100nF as per ESP.
The power rectifier and filter board connects to the pictured uPC1342V board via three twisted 16 AWG Remington Industries tinned stranded copper wires which are soldered to the –ve terminal of the amplifier board negative filter cap, the star ground "integrated in the amplifier PCB layout" pictured in the attached picture (red arrow) and the +ve terminal of the positive filter cap. (Soldered under the board, three orange arrows on the attached picture.) The amplifier board filter capacitors are 4700uF Samyoung rescued/recycled from stereo amplifiers.
The output is taken at the yellow arrow shown on the attached picture of the uPC1342V board. I have experimented with two return paths. First to the black arrow on the attached picture of the uPC1342V board. (That is what the PCB designer intended.) Second to the ground on the output side of the power rectifier board (seems to be better). Both configurations produce about 4x the expected 2nd harmonic relative to the datasheet.
The load is currently two EBG UXP/300 10 Ohm in parallel (5 Ohms, my speakers are 4 Ohms) on a large heatsink. They are connected with 16AWG tinned copper stranded Beldon wire.
The input to the E-MU (Channel B XLR) is via the balanced attenuator mentioned previously in this thread. It is made of two 10k and two 270 ohm resistors which are matched better than 0.1%. (Connected across the EBG UXP/300 load. Slightly better results when connected directly to the output terminals on the amplifier PCB.)
The speaker protection board is current not in circuit.
File Type: png 8 Vrms Battery Power Measure Across Load and Load Is From Designed Terminals.png (144.6 KB, 23 views)
Howto - Distortion Measurements with REWHide this!Advertise here!
Thread Tools
Distortion and Other Measurements ????? SyncTronX Equipment & Tools 8 29th April 2014 07:57 AM
Distortion measurements, THD, IMD-what card? Eugene Dvoskin Solid State 24 1st January 2011 07:11 PM
Distortion Measurements Nikon1975 Tubes / Valves 8 1st March 2010 01:57 PM
How to do IM distortion measurements? Conrad Hoffman Parts 1 28th May 2007 07:09 PM
Distortion measurements Vg Multi-Way 5 13th August 2004 12:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
