Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Advices on First Crossover Design (VituixCAD2)
Old 11th July 2019, 12:11 AM   #341
ScottG is offline ScottG  United States
Originally Posted by MrZoltan View Post
So I may be confused about words, when you say "baffle" do you say front panel of the cabinet ? (in green on the picture below)
If yes then does that mean I would make measurements at first without the actual cabinet but just that front part ?
The entire baffle: that's the entire front panel of the cabinet/box. ("green/mid-tweet integrated with black/woofer - single panel).
While you could split it up into two different cabinets as shown, I wouldn't.
When you go to measure for the mid. tweet, the full cabinet will provide more accurate results to the final result (..though the differences shouldn't be much different).
perspective is everything
Old 11th July 2019, 03:56 PM   #342
MrZoltan is offline MrZoltan
Why not separated ? It would be easier to redo just that part if need to adjust mid/high placement or remove/change that Fostex that I see coming.
BTW I just received the Radian LT2 from Thomann, and they did not deliver the dipole version as requested, lucky me as usual, I wrote them back to see how they plan to correct the mistake.
Also got that giant round-over router bit today straight from USA, seem to be well made at first glance
Old 12th July 2019, 04:54 AM   #343
IF you use both portions of the baffle for doing mid.-tweeter measurements, then yeah: should work well.
Can you remove the LT2's rear without damaging the terminals? (..that terminal damage is a problem with other cheaper planars like HiVi/Beston, but in the case of the Neo 3 it isn't a problem). If so, then you basically have the dipole version. I'd probably ask Radian 1st:
Support - Radian Audio
Wow, that was pretty fast shipping from the US. Good to hear that it arrived quickly and looks good.
Old 12th July 2019, 08:18 AM   #344
Yes that's the plan I'll keep the top & bottom baffle joined
Well I have left a message to Radian as well now.
On inspection I guess that the back could be removed without impacting the terminals, it's sealed with a sort of black glue tough and I consider that last resort as I don't want to mess up anything and voiding the warranty at the same time.
Here a few pictures so you can see for yourself the assembly :
Click the image to open in full size.Click the image to open in full size.
Old 12th July 2019, 06:43 PM   #345
Yeah Radian replied that the dipole version is available to OEM/ODM only and they are pretty adamant about it
They also do not provide any information or support about removing the back as I expected.
So either I open them myself but I am not sure I want to take the risk prying them open, if they end up damaged I will be at a loss.
I could also send them back and try to get a pair of Beston RT002A from cadaudio.dk
Or I could swallow the bitter pill and keep the drivers as-is for another eventual project and find another option anyway
There has been many bumps, first the dead Scanspeak, then the dead LT plan and now this, I start to be a tad frustrated.
Old 12th July 2019, 08:45 PM   #346
Is it a glue, or is it a plastic weld?
What I might do in this situation is simply remove/"shave"-off the top of the back-chamber first with a "coping" hand saw - which would allow me to inspect the interior chamber and joint. Even if you can't pry the glue/weld area off well: you've still got open-back at that point (though you'll likely need a bit of fiber/absorption around the remaining "wall" edges of the rear). ..Or of course, just try prying off the glue or weld joint with a hobby knife and take your chances.
-at around $60 (each I'm assuming), and without obvious problems from terminals, I'd say go for it. At worst you'll loose one driver and the time needed to get a new one.
CAUTION: when you start using these drivers - do NOT solder to the terminals, instead crimp connectors onto the ends of your wire (and then slide the connectors onto the terminals). Heating-up the terminals on these foil drivers just destroys the drivers.
Old 12th July 2019, 08:50 PM   #347
"Par for the course".
I had to "buy" my large inductor 4 times before I actually had it sent to me. (..twice from Erse and twice from Parts Express - with the 2nd one from Parts Express finally coming through, though no word when it shipped - it just arrived after a week and a half from that second order.)
By contrast that MCM order on the sub drivers arrived within 5 business days. And my average Amazon order (from Amazon) typically arrives within 3 business days (..without Prime of course).
Old 12th July 2019, 09:10 PM   #348
What I might do in this situation is simply remove/"shave"-off the top of the back-chamber first with a "coping" hand saw - which would allow me to inspect the interior chamber and joint. Even if you can't pry the glue/weld area off well: you've still got open-back at that point. Or of course, just try prying off the glue or weld joint with a hobby knife and take your chances.
I have no Idea what is that black stuff, I assumed it was some kind of glue because I don't suppose they would melt plastic to cover the nuts & bolts.
Imagining sawing that tweeter, give me the feeling that I would saw one of my bone
Sawing that cover would introduce nasty plastic particles into that ribbon under don't you think?
Close, It's $55.22 per driver at the current exchange rate
Yes mental note about soldering Ribbon Drivers, same with AMT ?
Old 12th July 2019, 09:26 PM   #349
Yeah, I have to take that with an ounce of philosophy
But you did get you money back from the undelivered other orders right ?
The Radian delivery was nearly twenty five days to arrive, I explicitly asked for a confirmation it would be the dipole version, I suppose the guy at Thomann that confirmed didn't bother to check with Radian first, I'm curious to see the answer they will give me about that.
Am I expecting too much ? Maybe, when I work with customers I always am honest and do not leave room for false expectations.
Old 12th July 2019, 09:32 PM   #350
I don't know about the AMT.. probably, but it's got a lot more surface area so perhaps less so?
It's just a plastic (ABS) cover - not very thick either. It really shouldn't be difficult to cut through that ABS. A lot easier than cutting through typical plumbing pipe, and that's not difficult either.
I wouldn't be worried about plastic filings: just tap and shake the driver a bit afterward and blow on it. Get a rub-buzz before hand along with an impedance trace. Any problems later will show up on the impedance trace.
Do the screws have anything to do with the cup/chamber we are interested in? I looked at your pic.s and it didn't seem that way.
Advices on First Crossover Design (VituixCAD2)Hide this!Advertise here!
Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux Tfive PC Based 337 8th July 2019 10:25 AM
Need Advices For 3 Way Speakers Design FlimsyFocalSpeaker Multi-Way 27 10th June 2016 11:58 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Upgrading crossover components, any advices? Ageve Multi-Way 5 15th April 2008 12:21 PM
Copyright ©1999-2019 diyAudio
