Dear all, can you recommend me tools for my upcoming smaller hobby projects ? I've some old but still quite good drivers which I cannot find a datasheet anywhere.. so I have to test them by myself.. I need Thiele-Small parameters, impedance curve, frequency curve.. can you recommend me a good, reliable software (and hardware if necessary) for that ?
Thinking of MLSSA, Dayton Audio's DATS & Omnimic.. any other maybe worth to try ? Has anybody tried DATS for accurate speaker driver measurement ? Can the Onmimic tool draw me a freq. curve (SPL curve) ?
Which one would you recommend from price/performance point of view ?
Thanks.
Thanks.
+1 to Jay's suggestion!
Hardware wise you need a sound card with line out and line in (headphone out may substitute for line out). You also need a cable or jig.
Cables Claudio's cable jig shows a 10 ohm resistor you may want to use 100 ohms.
I use a walin jig II similarly note that it uses an 8 ohm sense resistor, REW and ARTA I think both recommend a 100 ohm sense resistor. It works with 8 ohms but would probably be more accurate with 100 ohms.
Tony.
Tony.
Equally valid!
I bet those stone etchings for circuit boards get awfully heavy
What about the woofer tester 2 or dayton audio DATS 2.1.
woofertester.com
Dayton Audio DATS V2 Computer Based Audio Component Test System
woofertester.com
- Design & Build
- Equipment & Tools
- Useful tool recommendation for speaker & speaker driver measurements
