Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#31 | |
#32 |
Did you all see the fireworks and celebrations around the globe last night?
Well, the reason to celebrate was wedding day between SOCD and SIC: SOCD: A new Self oscillating class D amp was invented - no need to infringe on UCD patent. SIC: A new technology that enables 600V parts with fast usable body diode (unlike superjunction) and low Rdson. SOCD SIC: A revolutionary new multi-KW amplifier that will turn the whole world into one big partyland!!!! Let's get the party started! @kASD: I can see clearly the need to have the COMP inputs within specified limits, otherwise the COMP may misbehave. In case of my COMP it is -0.1V <-> VCC-1.2V. So why not just use zeners to keep the inputs where they need to be? No need for a common mode correction..... |
#33 |
Went from my WIN7-system to my WIN10-system to continue working on the amp simulation and the new WIN10 dows not let me edit the standard.dio! WTF??
Any idea? |
#34 |
Agreed as long as they are used for the power supply. Transferring pwm pulses with varying duty cycle is another story.
tuby or not tuby, that is here the question! |
#35 |
Was able to edit the standard.dio from OUTSIDE WIN10. I had to boot ubuntu to edit the file which has special protection from Windows.
Amp is working. I am adjusting minor details. |
#36 |
Thread | Thread Starter | Forum | Replies | Last Post |
Making easy DIY "Depot" sound Diffuser panels, step by step | bwaslo | Room Acoustics & Mods | 147 | 2nd July 2018 05:29 PM |
LTSPICE was wrong: MOSFET transconductance "gm" is NOT higher than bipolar gm | Mark Johnson | Solid State | 33 | 13th January 2017 12:18 AM |
Free: Small aluminum enclosure. 8" x 3" x 1.5" approx | ua100k | Swap Meet | 1 | 21st December 2014 06:48 PM |
6.5, 8", Chang, Sachikos? Xmas project | Bob, W7ETA | Full Range | 24 | 28th November 2009 08:15 AM |
suggestions; looking for shallow 10 or 12" woofer to work in small sealed box | zuki | Multi-Way | 6 | 1st April 2004 07:21 AM |
New To Site? | Need Help? |
