Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Installing and using ngspice - an opensource simulator
Old 13th April 2019, 01:42 PM   #181
astx is offline astx  Austria
Originally Posted by UltimateX86 View Post
If i could convert it to NGspice, i would probably switch
Attached your circlotron circuit simulation working using ngspice.
I have converted and cleaned up your ltspice ".net" output file. In principle it should run with current "ngspice pre-master" which includes the fix to allow "{}" calculations in ".model" parameters.
At simulation start you get this error:
Cannot compute substitute
Copies=56 Evals=114 Placeholders=4 Symbols=3 Errors=6
Numparam expansion errors: Run Spice anyway? y/n ?
Just ignore it with "y" to continue because the errors are due to unallowed model parameters like "mfg" which are of no relevance here.
BR, Toni
Hint: have a look at first post of my threads for an updated index!
Old 13th April 2019, 01:48 PM   #182
Originally Posted by hvogt View Post
In fact it is possible to use temperature, voltages and currents in model parameter expressions. There was a bug in the parser for the VDMOS model. I have pushed a fix to branch pre-master.
Concerning the self heating models, we still have some discussions about the final implementation.
Thx Holger for the very fast fix! Works now with Ian's ltspice models.
See above example of the "circlotron".
About the vbic and vdmos self heating: is there a plan when it will be production ready and merged into pre-master/master?
BR, Toni
Old 13th April 2019, 02:15 PM   #183
edbarx is offline edbarx  Malta
I have gSpiceUI installed but I was discouraged from using it the few times I tried it. My impression was immediately a very steep learning curve ahead. I reasoned if I wanted others to read my circuits and help me in case of difficulties, it was far more practical for me to use LTSpice instead.
Trying it another time I got the impression I was using KiCad. LTSpice is far simpler to use and used by many more people.
Old 14th April 2019, 10:16 AM   #184
Your opinion here is a bit off topic: we are not discussing which schematic gui is intuitive/better - we are discussing ngspice - the simulator core itself. Feel free to start your own thread/poll discussing gui features of open source schematic editors vs commercial (and currently "freeware") ltspice schematic editor.
BR, Toni
Old 14th April 2019, 11:04 AM   #185
... maybe the learning curve is high, but the results of one sim run makes really fun and speeds up the development exponentially (as one of many benefits it helps to avoid a carpal tunnel syndrome). Attached a screenshot of a high power class G amplifier in development using 8 pairs TTC5200/TTA1943 and 8 pairs IRFP240/9240.
Includes SOA of VAS, drivers, output drivers of all 5 power steps
tian probe results of feedback loop and vas feedback loop
fft, harmonic distortions, output power etc ...
Thanks to David Zan supporting me with outstanding good ideas for going green!
Have fun, Toni
Old 14th April 2019, 02:15 PM   #186
All right, granted. If the simulator engine (core) is that powerful it is worthy of a good look. I tried to install the core but ngspice is not available in the distribution's repositories although gspiceui has references to it.
Code:
$ apt-get install -s ngspice
NOTE: This is only a simulation!
      apt-get needs root privileges for real execution.
      Keep also in mind that locking is deactivated,
      so don't depend on the relevance to the real current situation!
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package ngspice is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ngspice' has no installation candidate
Old 14th April 2019, 02:42 PM   #187
All recent major distributions (opensuse, redhat, debian, ubuntu ...) have ngspice available. At least they provide extra repositories where you can download it.
Whats your distro and version?
Old 14th April 2019, 02:49 PM   #188
hvogt is offline hvogt  Germany
I have pushed a fix to branch pre-master to get rid of the 'mfg=whatevername' issue.
Holger
Old 14th April 2019, 03:13 PM   #189
Old 15th April 2019, 08:06 AM   #190
UltimateX86 is offline UltimateX86  France
BR, Toni
Thank you so much !
I do not sell anything, I'm just trying to build a www.circlotron.audio
Installing and using ngspice - an opensource simulatorHide this!Advertise here!
NGSPICE UltimateX86 Software Tools 4 1st December 2014 06:03 PM
Help with esl simulator pforeman Planars & Exotics 6 13th July 2014 03:56 AM
Cab/Mic simulator Mishung Analog Line Level 0 14th November 2010 02:13 PM
DAT Simulator jman 31 Instruments and Amps 4 1st February 2009 01:44 PM
who got the best simulator prorms Solid State 5 26th December 2006 05:39 AM
Copyright ©1999-2019 diyAudio
