Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Klippel Near Field Scanner on a Shoestring
Old 12th January 2019, 07:29 PM   #521
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by scott wurcer View Post
Good to know I'm not the only one (69 in two weeks). My sister took me to the Tiffany museum Winterpark FL the restoration of the chapel from the World's Fair is worth seeing.
I've seen it. The best display is in NY at the Historical Museum.
Earl Geddes Gedlee Website
Old 13th January 2019, 05:47 AM   #522
Dave Zan is online now Dave Zan  Australia
Originally Posted by gedlee View Post
I don't see how FEM/BEM would aid in this task in any way...
It's not for this task, it's just a new machine with sufficient speed for BEM.
So it should have more than ample speed for any plausible calculations on this task.
Best wishes
David
Old 15th January 2019, 07:38 PM   #523
Ezcl is offline Ezcl  United States
How one gets the impulse response is not critical, although some methods are better than others, and some programs will output an array of data - as required - and others won't. I built my software around HolmImpulse and it works very well, but any means of getting a single file with the impulse responses at various angles will work.
As to myself, ...
My intention is to get back to this, but my circumstances are not making that easy.
Sounds good to me, and that's certainly understandable - I'm fairly certain we all have more things we'd like to do than we are able, no matter our age.
I ask about the data format because I have built a tool that automates polar measurements at work, and I'd love to spit out the correct format for use in this tool. Is there an example of the proper data somewhere in this thread? If not, could one be posted so I can follow it?
Old 15th January 2019, 09:19 PM   #524
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
I added the commonly available formats and mostly added some comments to explain the format, for the most part this means expecting a directory full of files which are named according to the angle they represent and that contain data in some known format. The supported formats being
- wav
- dbl
- ARTA PIR
- REW txt format
There is then the HolmImpulse export format which is described in pypolarmap/load.py at master * 3ll3d00d/pypolarmap * GitHub
This is a semi colon delimited format where the angles have been embedded in the header (aka the measurement names) as a convention
Klippel Near Field Scanner on a ShoestringHide this!Advertise here!
Klippel R&D Measurement Methodology SUBduction Multi-Way 3 11th December 2016 05:37 PM
TB W3-1878 Klippel graph aarvin2 Full Range 3 18th November 2012 04:04 PM
Why doesn't DIYAUDIO have a klippel? JZatopa The Lounge 26 14th November 2011 03:40 AM
Vinyl Scanner? Nehesi Analogue Source 37 20th July 2011 09:29 AM
TD15M, does anybody have one willing to donate for Klippel testing? thadman Multi-Way 71 4th September 2009 04:10 AM
Copyright ©1999-2019 diyAudio
