Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
VituixCAD
VituixCAD
Old 2nd October 2018, 10:14 PM   #601
rich08 is offline rich08  Slovakia
Originally Posted by kimmosto View Post
Rev 2.0.5.0 (2018-10-02) with IR to FR conversion is out now. This software is more or less beta all the time
Manual in EN will be updated in few days but I suppose FFT tool should be quite easy to learn if one has played with measurement softwares.
Kimmo thank you, very good feature. The common impulse and frequency window is an excellent idea, clear, fast, missing in some measuring systems.
Old 3rd October 2018, 10:20 AM   #602
kimmosto is offline kimmosto  Finland
kimmosto's Avatar
^Thanks!
Manual in English updated for rev. 2.0.5.0 (refresh if needed). German translation has been delayed for few months due to continuous changes. Maybe it's good time to update that too.
I can add support also for other than ARTA pir and CLIO mls files, if specification for binary file format is available. I'll leave searching, asking/begging and investigations to users who need to convert other IR formats to frequency responses.
Generally, I'm hoping that adequate FFT features would be available in measurement programs. External tools and add-ons need (free) work and using is extra step in design procedure.
Old 3rd October 2018, 11:31 AM   #603
DBMandrake is offline DBMandrake  Scotland
DBMandrake's Avatar
Wow, very nice.
I particularly like the real time update of the frequency response while the cursors in the impulse response are being adjusted. This is great for seeing the effect of reflections in the impulse response and avoiding them.
I did have a strange issue where choosing FFT length 4096 or 8192 was causing a large shift in the signal level in the FR window relative to other FFT length choices, but after opening a few different files I'm not able to reproduce it again.
- Simon
Old 3rd October 2018, 12:05 PM   #604
kimmosto's Avatar
Originally Posted by DBMandrake View Post
I did have a strange issue where choosing FFT length 4096 or 8192...
Most probable reason is that 4096 and 8192 were shorter than total length of time window. Manual adjustment of FFT length is possible after window adjustments are done but shortening of automatic selection has some risks.
Automatic selection is possible to lock, but that would prevent user to increase accuracy/resolution at low frequencies. Limiting of shortest possible FFT length would be more sophisticated and user friendly.
Old 3rd October 2018, 01:36 PM   #605
kimmosto's Avatar
This is done to the latest build a minute ago.
Old 3rd October 2018, 01:40 PM   #606
mV8 is offline mV8  Poland
Thank you Kimmo for Impuls Converter. It works great.
Old 3rd October 2018, 05:26 PM   #607
aczern is offline aczern
Kimmo
If an active filter has a bypass button, it will better displays a change.
Old 3rd October 2018, 09:03 PM   #608
kimmosto's Avatar
^Could you tell me where you don't see a change?
If you mean Invert bypass [B] button in version 1.1, that inverts bypass status of all blocks in selected way. No problem to create and set up filter chain which does not change transfer function when bypass statuses are inverted.
Old 6th October 2018, 09:39 AM   #609
kimmosto's Avatar
Please download and install the latest build of rev 2.0.5.1 (2018-10-06) to get all new and modified features listed in changelog:
* Reading of txt/frd/zma files changed more flexible to allow empty lines, comments between data rows, scientific notation and comma as field separator.
Conversion IR to FR
* Added magnitude scaling.
* Added 'Info header' checkbox. Writes metadata to output files.
* Added support for drag&drop.
Old 6th October 2018, 01:06 PM   #610
b_force is offline b_force
I am trying VituixCAD now in Wine on Linux.
I just used the manual on the website.
I only have two major issues;
1 - moving parts is extremely slow when the grid is on (when grid is turned off it works fine)
2 - if I go to options I get a error "InvalidArgument=Value of '-1' is not valid for 'index'
This is the log file;
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of '-1' is not valid for 'index'.
Parameter name: index
at System.Windows.Forms.ComboBox.ObjectCollection.get _Item(Int32 index)
at Vituixman.FormOptions.RBmCpnukLF(Object , DrawItemEventArgs )
at System.Windows.Forms.ComboBox.OnDrawItem(DrawItemE ventArgs e)
at System.Windows.Forms.ComboBox.WmReflectDrawItem(Me ssage& m)
at System.Windows.Forms.ComboBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
VituixCAD2
Assembly Version: 2.0.5.1
Win32 Version: 2.0.5.1
CodeBase: file:///C:/Program%20Files/VituixCAD/VituixCAD2.exe
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Numerics
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Core
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Accessibility
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
hjiylwi3
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
VituixCADHide this!Advertise here!
Copyright ©1999-2019 diyAudio
