Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
VituixCAD
VituixCAD
Old 19th May 2019, 08:29 AM   #1231
kimmosto is offline kimmosto  Finland
kimmosto's Avatar
^PM is disabled. e-mails only, please. Address in About box of VCAD or at home page.
Old 19th May 2019, 10:33 AM   #1232
kimmosto's Avatar
Rev. 2.0.18.1 (2019-05-19)
Main program
* DCR of inductor calculated when L changed with mouse wheel or up/down buttons. DCR *= (Lnew/Lold)^0.59
* DCR of inductor calculated when wire diameter changed with mouse wheel or up/down buttons. DCR *= (Dold/Dnew)^1.6
Old 19th May 2019, 10:35 AM   #1233
Draki is offline Draki  Macedonia
Originally Posted by murph9666 View Post
Hi...new VituixCAD user here. I use DATS to generate .ZMA files and Omnimic to generate .FRD files. In V2, those file don't seem to work. They did in V1.1. Are they supported in V2?
Sorry if this has been asked before, but I couldn't find it in the thread.
Just in case you missed these bits:
- To generate any signal, you must first connect the source with the driver in the crossover tab. The connecting line will go green;
- The frequency response files must be saved as "XXbass_hor_deg_00.txt" in Omni. This is in case of on-axis measurement, for other angles you will replace the 00 with the appropriate angle value.
- The impedance file should be good as it is (once the driver is activated...)
Hope this helps.
Old 19th May 2019, 11:26 AM   #1234
kimmosto's Avatar
^Yes, missing XO was the problem already solved via e-mail.
First steps with ver 2.0 start here: How to start working with VituixCAD
P.S. "deg" in frequency response filename is not required. It's just naming system of ARTA. For example "Driver123 hor 0.txt/frd" (with spaces) is perfect for axial response if also driver name contains numbers. "Driver123 hor -170.txt" for -170 deg off-axis, "Driver123 hor 150.txt" for +150 deg, and so on.
Old 19th May 2019, 11:46 AM   #1235
Thanks, good to know.
Old 20th May 2019, 07:20 PM   #1236
DBMandrake is offline DBMandrake  Scotland
DBMandrake's Avatar
I just updated for the first time in a while, and I seem to have lost the vertical scrollbar for the schematic pane ? The horizontal scrollbar is still working.
Not sure exactly what version I was running before, I think somewhere around 2.0.13.x, so I have jumped quite a few versions.
As upgrades are normally problem free for me I didn't even keep the old installer to revert. Fortunately I can scroll vertically using trackpad two fingered scrolling as a workaround.
- Simon
Old 20th May 2019, 08:12 PM   #1237
kimmosto's Avatar
^Panel was too wide and vertical scrollbar outside visible area. Probably after BiQ button was added to rev. 2.0.15. Now there is new built of 2.0.18.1 where vertical scrollbar is visible again.
I wouldn't use this program without mouse because many important functions are done especially for mouse wheel.
Old 20th May 2019, 11:07 PM   #1238
DaveFred is offline DaveFred  Canada
Hello kimmosto,
What does the steel blue line "minimum phase" represent in a crossover design?
Thank you,
David.
Old 20th May 2019, 11:36 PM   #1239
kimmosto's Avatar
^Steel blue in GD & Phase chart is 'Excess group delay' of total response to reference angle. The same color in SPL chart is 'Excess phase'.
Old 20th May 2019, 11:49 PM   #1240
Originally Posted by DaveFred View Post
Hello kimmosto,
What does the lime green line "minimum phase" represent in a crossover design?
Thank you,
David.
Opps, asked about wrong colour...
VituixCADHide this!Advertise here!
Copyright ©1999-2019 diyAudio
