Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Calculation of SMPS resonant parts
Old Yesterday, 01:26 PM   #61
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
It seems to me that you are complicating a simple thing like a SMPS. All capacitances will be combined in one, reflected to the primary, that will became part of the resonant tank, together with the MOSFET's and diodes' capacitances. Also, surely you will need to add a fixed larger capacitor to ensure the highest frequency the SMPS can reach at lower loads, or driving the MOSFET's will be a problem and efficiency at low load will became a large headache.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old Yesterday, 01:43 PM   #62
kees52 is offline kees52  Netherlands
As I have seen, and read for low loads the controller go into skip mode or burst mode, that is the way a open output is done normally. But it did work also when play with the Lr/Lm ratio
For me I have to learn some more so I do this things because of that, I do not that the resonant tank is a whole setup of capacitances and inductions around it, the mosfet capacitances however do not that much, in calculation programs I do never see that I need to include them, for as what is needed, I have need more voltages and as such and no calculator I do play some around.
Hva now installed ultiboard dos, I go make a pcb and do experiment in real time, go make a protection for the high voltages first, a ground fault circuit breaker or such.
regards
Calculation of SMPS resonant partsHide this!Advertise here!
1kW resonant SMPS mag Power Supplies 44 21st March 2015 02:35 PM
Resonant frequency calculation Kooshball Multi-Way 11 3rd December 2012 05:59 AM
SMPS for Class D....resonant or not? eem2am Power Supplies 4 4th January 2012 10:56 AM
Resonant SMPS Serge66 Power Supplies 3 6th December 2007 08:26 PM
Resonant SMPS DFI Parts 1 5th December 2007 08:24 PM
Copyright ©1999-2019 diyAudio
