Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Installing and using LTspice IV (now including LTXVII). From beginner to advanced.
Thread Tools
Old 24th July 2021, 05:01 PM   #2961
Mooly's Avatar
Your confusing me
Do you see the single text file that was in the zipped folder?
It should be slotted in somewhere amongst all the sims.
You only need that one file for all the sims to work.
If you can't see how it works then try this. The model file is called poundys models and the sim has been altered to suit.
Just extract the zipped folder and run the sim (it won't run from the zipped folder, you must extract the contents). Don't alter anything. The sim should run and it will take a few seconds to complete as it is a complex one. You can then see how it works and how the model file is identified.
Old 24th July 2021, 06:41 PM   #2962
poundy is offline poundy  United Kingdom
poundy's Avatar
ok got it all working, i couldnt get it to work keeping in in the file folder so i dumped it into 'c'
Old 24th July 2021, 06:44 PM   #2963
Mooly's Avatar
That is very very strange but as long as you have it working OK. Models were (and are) one of the most difficult aspects of LT to me. It took me ages to get it to work at first.
Old 25th July 2021, 01:49 PM   #2964
madis64 is offline madis64  Estonia
First my apologies if this has been handled in the previous messages of this thread - but I cannot find any information with internet search either.
I stumbled across strange voltage values of the same signal when doing a simulation of Yamaha A-700 power stage (yes, with wrong component models but better these than nothing).
So I downloaded the zip file from
and tested it also on the Pioneer A80 model from there.
Same inconsistency appears - voltages in ac simulation are greatly different from voltages in tran simulation:
Am I doing something very wrong or thinking very wrong or using the software in a wrong manner here?
Old 25th July 2021, 02:03 PM   #2965
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I can't see anything wrong here. The freq. response looks good and the time waveform looks fine too.
What is the problem you see? What is the level of test voltage you specified for the .ac?
Jan
Old 25th July 2021, 02:04 PM   #2966
240V as output on ac simulation plot seems strange.
Old 25th July 2021, 02:17 PM   #2967
jan.didden's Avatar
Depends on the test voltage value you specified. If you change the scale to dB, does it look more like you would expect?
(Move the cursor in the scale area until it changes to a scale, right click, change to log).
Jan
Old 25th July 2021, 02:34 PM   #2968
The simulation command is from the original file:
and ac voltage for input seems to be set to 1V.
Power line for output stage is 60V:
Result in db:
, same converted (in plot window) to V:
How can 240V output signal be obtained from +/-60V power rails?
Old 25th July 2021, 03:58 PM   #2969
jan.didden's Avatar
.ac doesn't look at the actual circuit level capabilities. It simulates with the devices linearized around the DC point, really a very small signal, and the .ac level specified in the command is only used to set the scales of the graph.
240V if you set the .ac at 1V only tells you that the gain is 240x, about 48dB. What is the gain of the amp?
You set the test signal level for graphing in the top right corner see attachment.
Jan
Old 25th July 2021, 04:16 PM   #2970
Ok, starts to make sense. So to have realistic values in amplifier ac analysis one should adjust the ac signal level so that the output voltage more or less matches the device actual (or designed) levels?
Regarding the gain of the amplifier - cannot tell, I just took the model from Mooly's package.
But technical specs are given for input sensitivity 150mV, power rails for output transistors seem to be around +/-60V.
Transient simulation shows that 150mV input corresponds to 35V output (P2P). Clipping (in the simulation) starts around 240mV input signal.
Installing and using LTspice IV (now including LTXVII). From beginner to advanced.Hide this!Advertise here!
Thread Tools
[LTSpice] Beginner - help with capacitor multiplier? bugbear Power Supplies 17 11th November 2016 11:18 PM
Meistersinger VFA-200, A beginnerís first try in LTSpice nattawa Solid State 34 29th January 2016 01:58 PM
Including a C- winding on a filament transformer AllenB Tubes / Valves 2 8th May 2014 05:17 AM
Need help installing LTSpice rif Software Tools 4 30th May 2013 01:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
