Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
Thread Tools |
#921 |
Yeah, usually more info is better than less
![]() Anyway, the key principle for this xover is more impulse timing optimization than FR. I find timing the most underappreciated and undervalued feature in speaker design. That's why coax is here ![]() Last edited by pawelp; 24th January 2021 at 01:17 PM. |
#922 |
In that case, could you have Xsim show the individual responses as well as the circuit.
#923 |
Also coaxial can have excess group delay due to crossover such as any other multi-way. Also time alignment (including excess GD) could be off. So there's not much difference - certainly not so much that you should ignore something else.
#924 |
Just look the datasheet. Is on-axis, 30 deg or 60 deg the right one and representative for crossover design or not? Or is it electrical response based on assumption that tweeter of coax converts balanced electrical power to balanced acoustical power?
Single off-axis response could be representative, but the problem is to know which one. |
#925 |
>Also coaxial can have excess group delay due to crossover such as any other >multi-way.
Obviously, but this has little to do with coax. >Also time alignment (including excess GD) could be off. Do not get it - for me this sentence is basically the same as the previous one - no time alignment but solely due to the xover. So you "just" ![]() >So there's not much difference - certainly not so much that you should ignore >something else. For me there's a whole lot of difference - without a coax you have a serious built-in compromise in time alignment and the xover is rather on top of that. It is not about ignoring just setting the priorities for the case they cannot be optimized simultaneously Last edited by pawelp; 24th January 2021 at 03:37 PM. |
#926 |
The mid and twt part - I am focused on them for now.
Maybe someone could give me a hand where to find a tool that would calculate a notch (RLC) for the 4k peak - 5dB, Q=5 ? Last edited by pawelp; 24th January 2021 at 04:14 PM. |
#927 | |
![]() Some real life 4-way with separate conventional drivers: ![]() Built-in compromise in time alignment is quite well handled isn't it? ![]() |
#928 |
The 4-way seems to look nice. The question is at what mic location was the measurement taken and how it changes with a few cm mic repositioning.
I am always interested in alternative points of view. So in my practical Seas coax drivers case what would be your approach to xover design ? |
#929 |
Interesting discussion and example
![]() My first impression of this IR was it is not my high fidelity. But if understand this correctly on a fast glance actually the key timing problem here is the woofer being delayed and that's less of a problem. The mid and twt are not fully in sync but how problematic it is would need some closer analysis and comparing how it compares to other commercial products. What is your view on that ? If you attached a well-behaved 4-way doesn't it mean you also pay quite a bit attention to it ? ![]() Last edited by pawelp; 24th January 2021 at 04:46 PM. |
#930 | |
Old guy with soldering iron
But XSim was designed to be mostly used iteratively, to avoid things like needing formulae and related tools. Put in the component arrangement for what you are after, then scroll through values of eac components to see what happens -- it doesn't take long to get a feel for what is going on or for the size of inductors, resistors or capacitors that affect the frequencies you desire. I think that way is more instructive than using some online calculator (which seldom gives the expected results when attached to real world impedances like those of drivers). BTW, it might be better if you attached the '.dxo' file for your crossover to your post. Then other people can start with what you have, including the driver responses and impedances you are using (those are part of the .dxo), Not many members here will want to spend the time to enter the circuit by hand and guess what your drivers behave like. With a dxo, they can just click, open, and play with components. edit: for example, download (click in most browsers) to get this example, play with C6 to see how it behaves, then with other components like L4 and R5.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns; Crossover design Xsim; Depot diffusor super-easy diffusors Last edited by bwaslo; 24th January 2021 at 06:40 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Update to Windows Passive Crossover Designer available | dlr | Software Tools | 1 | 15th May 2014 11:46 PM |
Windows Passive Crossover Designer v1.2 available for download | dlr | Software Tools | 15 | 14th December 2013 12:48 AM |
Active Crossover Designer version 2 released | CharlieLaub | Software Tools | 1 | 12th November 2012 10:08 PM |
Orcad/AutoTRAX EDA - free schematic capture/PCB designer | Ilija | Everything Else | 3 | 16th July 2003 12:11 PM |
New To Site? | Need Help? |
