Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
XSim free crossover designer
Old Today, 10:15 AM   #641
Mazza is offline Mazza  Australia
Default Designing for dual woofers?
Dear Mr Waslo and all,
I have a very nice pair of Klipsch KG 5.5's that I want to improve. These are a TWW system; horn loaded dome tweeter with a pair of 10"woofers in a two way arrangement.
I understand that dual woofers in a two way means lobing in the vertical axis.
My question then is; is it possible to improve the system keeping the 2 way configuration through the crossover?
Some data attached to show my approach:
Measured the woofers look like this:
XSim free crossover designer-kg-woofer-comparison-jpg
The both woofers running simultaneously have a big dip between 1.5 and 2k that is affecting speaker with the original crossover:
XSim free crossover designer-kg-5-5-xsim-original-crossover-graph-jpg
And yes, these are way HOT to my ears!
Here's the original crossover:
XSim free crossover designer-kg-5-5-xsim-original-crossover-schematic-jpg
My solution to this is as follows:
XSim free crossover designer-kg-5-5-xsim-crossover-schematic-jpg
The result is much improved:
XSim free crossover designer-kg-5-5-xsim-crossover-graph-jpg
What I am keen to know then is if the woofer lobing can be effectively fixed with this crossover or am I just optimising at the measured distance? Put another way, is the dual woofer arrangement still causing problems that may not be evident in my crossover simulated response?
DXO attached for reference.
Thanks!
File Type: jpg KG 5.5 XSim new crossover schematic.jpg (59.3 KB, 37 views)
File Type: jpg KG 5.5 XSim original crossover schematic.jpg (44.7 KB, 37 views)
File Type: jpg KG 5.5 XSim original crossover graph.jpg (106.6 KB, 29 views)
Old Today, 03:52 PM   #642
mwmkravchenko is offline mwmkravchenko  Canada
mwmkravchenko's Avatar
Hello Mazza.
Just throwing out an idea. Any problem with turning the system into a 2.5 way? Second woofer closer to the floor gets a low pass?
Mark
www.kravchenko-audio.com
Old Today, 04:03 PM   #643
perceval is online now perceval  Taiwan
perceval's Avatar
your new XO looks a 1000 times better than the old, in the FR department.
How about the step response and the impulse with the new XO, how does that look?
XSim free crossover designerHide this!Advertise here!
Update to Windows Passive Crossover Designer available dlr Software Tools 1 15th May 2014 10:46 PM
Windows Passive Crossover Designer v1.2 available for download dlr Software Tools 15 13th December 2013 11:48 PM
Active Crossover Designer version 2 released CharlieLaub Software Tools 1 12th November 2012 09:08 PM
Orcad/AutoTRAX EDA - free schematic capture/PCB designer Ilija Everything Else 3 16th July 2003 11:11 AM
Copyright ©1999-2019 diyAudio
