do you mean with timealignment handbook the SATlive
user manual or some other pdf document ?
link to that new handbook would be nice to get
there is the handbook and a only timealigment pdf - also there are webinars on edudip
edudip.com | Plattform fur live Online-Seminare, Webinare
SATlive - First Steps
5.12.2018 at
5.12.2018 at
MfG -
- great to have webinars available
- Link to edudip com/all/webinars?esearch=satlive : Online-Seminare, Webinare
new Version out
and there is a new article series online Fridays for Features - more Measurment related and very informative
SATlive - Friday for Features
have fun
have fun
new Version out
SATlive Version 1.70.50 - Messtechnik - PA-Forum
SATlive Audio Measurement Software - have fun
New Version SATlive 1.7.052
The current version
Load down the most current version of SATlive.
Most current version: 1.70.52
New: Tags for quick labeling of quicktraces.
New: Global layout options for quicktraces in the IR Module.
Fixed: Free – Run and Single – Shot trigger for oscilloscope now work as intended.
New: Triggerlevel can be displayed in oscilloscope.
New: Tags for labeling quicktraces in web-interface.
New: Auto – fit option for IR display in web – interface.
Improved: Performance and stability of the web – interface improved especiall when running on slower network connections.
Improved: Calculation and parameters for Schroeder – trace and room – acoustic calculations improved.
Previous Versions
Fix: Virtual Eq gain jumps when changing Q.
Improved: CSV Export now supports correlation.
Improved: Free – Run and Single – Shot trigger for oscilloscope.
New: Delay – suggestion tool: optimization target max +/- 60° difference in phase added.
Improved detail – display for delay – suggestion tool.
Improved: Waveform selection and display in signal – generator.
Add: Time – Marker Export / Import added.
Add: Time – Marker will show polarity information.
Add: Transfer – function fast refresh option for faster update of the low – frequencies in transfer – function measurement.
Add: Control – Output option added to configuration menu.
Fix: Delay – Info display flashes in some cases.
Fix: Virtual Eq not working on sum – trace.
Fix: Mixed up Bessel and Butterworth filter types in the virtual crossover.
Added a simple wav-file player to the signal – generator
Tracemanager will show amplitude responses in the background of the impedance measurement
Single window display of phase and amplitude in impedance measurement
Quicktrace buttons can be magnified
Global link for smoothing
Fix: Some errors related to group – delay display
Internal improvements and fixes
Option Show QT on Assign to control the display of a quick – trace after its assignment added
Web – client added selection of ASIO routings to menu Main
Key – combination Shift – A will zoom the vertical scale of the IR display to fit the delay zoom window
Key – combination Shift – P sets cursor to peak in the delay zoom window
Fix: Complex – Combination not working in MLS white and MLS pink
Fix: Quick – traces created using previous versions of SATlive will not load
Fix: Some peq settings will not show in the web – client
Fix: Header will not change while changing Q or Bandwidth in the peq using sliders
Combined delay – latches and time – markers
Automated File – Name Creation in the IR module allows sequential saving or measurements
Delay Zoom Window in MAT → IR can now center at the cursor position
Local peak – finder in the Delay Zoom Window
Peak position and local – peak now available in the delay – matrix
Delay – Matrix added to the web – client
Delay – Finder added to the web – client
Remote start and save option for IR – module
Reordering / Clean – up of some menus
For the complete download click here.
Load down the manual only.
Language files for other countries.
Hint: You can demo the software for 30 days. Please see the manual for details.
The current version – SATlive – Your Audio Measurement App
The current version
Previous Versions
SATlive Online DAy 23.4.2020
SATlive Online Tag am 23.4.2020 - Termine - PA-Forum
Nachdem der erste SATlive Online -Tag gut verlaufen ist, wage ich eine Wiederholung.
Der geplante Termin ist Donnerstag, der 23.4.2020 von 9:30 bis 17:00
Geplanter Ablauf:
Block 1, 9:30 bis 10:30
Begrüßung, Einführung. Bei Bedarf kurze Hinweise zum Start von SATlive.
Einführung in die FFT und die Dual – FFT
Erste Messungen im RTA, FFT und in der Übertragungsfunktion.
Möglichkeiten der ‚Qualitätssicherung‘ in der Übertragungsfunktion.
Einstellung der Darstellung in SATlive.
Block 2: 11:00 bis 12:00
Die Impulsantwort.
Messungen mit der Impulsantwort (Delaylines).
Einführung in die Phase.
Die Überlagerung von Signalen.
Block 3: 13:00 bis 14:00
Laufzeitanpassung zwischen Top und Subwoofer mit Hilfe der Phasenkurven
Vorstellung der Tools Live - Überlagerung und Delayvorschlag.
Block 4: 14:30 bis 15:30
Grundlagen der Equalizereinstellung
Der virtuelle Eq in SATlive
Weitere Features in SATlive (Sub-Delayfinder, Projekte, ASIO Konfiguration … )
Block 5: 16:00 bis 17:00
Bei Bedarf Vertiefung einzelner Punkte
Fragen der Teilnehmer
Das Webinar ist kostenpflichtig ( 50 Euro inkl. MwSt) und die Teilnehmeranzahl ist begrenzt.
Die Anmeldung erfolgt über diesen Link: SATlive Online Tag
Ich freue mich auf Euch Thomas Neumann
Sim II Operator - DANTE Level I-II-III
SATlive (Kommerziell!) SATlive Audio Measurement Software,
LevelCheck (Kommerziell!) LevelCheck
Geplanter Ablauf:
Die Impulsantwort.
New Version
Most current version: 1.70.64
New: K-View using two impulse-responses.
Improved: Display update speed in MAT – impulse response.
Some minor GUI changes
Some internal fixes and improvements
Previous versions
Added K-View (cross-correlation based delay location).
Modified Delay – Suggestion Tool.
Improved resolution and latency for FFT and Spectrograph in MAT Module.
Added STI-List.
Changed: Layout of the amplitude – threshold setting window.
Changed: Noise – Threshold area visibility controllable in setup -> measurement.
Fixed: Trace color changes not saved to dongle.
Fixed: Align of QT Buttons when magnified.
Fixed: Interaction color indicator remains in IR and FFT.
Fixed: Sum-Trace selection remains when Sum-Trace does not show.
Improved: Virtual X-Overs supports All-Pass Filter (first and second order).
Improved: Results of the Delay-Suggestion tool now available in the Virtual-Time-Shift window for easy verification.
Improved: Shortcut Ctrl + Alt + R centers and sizes window.
Fixed: Exit of transfer – function measurement takes too much time.
Fixed: Loading acoustic data created by previous versions of SATlive spoil acoustic parameter window.
Fixed: Some minor internal fixes and improvements.
Fixed: Displaymode settings not saved for frequency-range display.
Improved: Frequency-range selection.
Fixed: RTA selected bar shows wrong color ( classic color only).
Fixed: RTA mic input will not show peak.
Fixed: RTA frequency zoom does not work correctly.
Add: Time – Marker Export / Import.
Previous versions
Added STI-List.
new version
SATlive Version 1.70.68 released
Most current version: 1.70.68
Fix: Error during stop of audio-driver (ASIO and DirectSound).
Fix: Wrong file-info display when no valid file is available.
Added: Threshold for amplitude difference in Delay-Suggestion-Tool.
Added: Visualization of frequency – range used during calculation of delay – suggestion.
Previous Changes
New: Compensation of measurement-delay difference for live-add trace.
Fix: Update connection problem.
Fix: Smooth settings for MAT-FFT.
Fix: Wrong creation-date info (quick-traces).
Minor GUI improvements
Added STI-List.
Previous Changes
Added STI-List.
- Design & Build
- Software Tools
- SATLIVE and LEVELCHECK by Thomas Neumann
