Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 23rd December 2012, 04:01 PM   #21
pos is offline pos  Europe
pos's Avatar
Originally Posted by peterhenk View Post
Thank you for the reply,
I am using a mac as source, and a heavily modified DCX. So I will be playing around this Xmass with your software!!
Merci
Peter
Great!
Do not hesitate to come back with any question, suggestion, ... bug report
Old 23rd December 2012, 04:04 PM   #22
pos's Avatar
Originally Posted by Pano View Post
Wow, how did I miss this before? Will try this for sure. Thanks for posting.
And I will be very interested in reading your insightful comments
Old 23rd December 2012, 04:07 PM   #23
Davey is offline Davey  United States
Great job on this pos.
I set up my Foobar configuration (foo convolver) a few weeks back to implement a simple three-way with the "Filters Linearization" portion and it really does work well.
Dave.
Old 23rd December 2012, 04:44 PM   #24
Pano is offline Pano  United States
Pano's Avatar
OK, how does one proceed? I think I understand the basics, let's see.
  • Passive filter
  • I know that my acoustic slopes are L/R 4th @ 825Hz (measured)
  • My box is vented, low Q, 35Hz
  • I enter those values in the Filters Linearizion tab
  • Export the impulse to use in a convolver.
  • I can check this impulse in HOLM to see how well it matches my measurements.
Are those the basic steps?
Take the Speaker Voltage Test!
Old 23rd December 2012, 05:05 PM   #25
natehansen66 is offline natehansen66  United States
Originally Posted by pos View Post
Hi Peter,
To do so you will only need to dial the filters you are using in your DCX in the "filter linearization" tab in rePhase, and generate an impulse for these (ideally you will want to dial your acoustical filters, not only the electrical ones...).
This is similar to phase arbitrator (which happen to have a user manual )
Can this be done in a single impulse, or will there have to be phase correction for each channel separately?
I use J River's convolver but am having issues with their loopback using multi-channel convolution (I used rePhase to generate linear filters for my 3-ways), but others report that 2 channel convolution works fine. I'd like to build my crossovers in JR's PEQ and do the phase linearization if possible with a single impulse.
Old 23rd December 2012, 06:43 PM   #26
twest820 is offline twest820
(moving rePhase and related phase linearization discussion over from the Hypex DCLP thread)
Interesting software! Have you implemented a real-time version?
It would be similar to Phase Arbitrator in its implementation I think (inverted overlapped buffers).
Arbitrator doesn't overlap the buffers, just emits them sequentially with whatever discontinuity in the output may result. If you grab the demo and measure THD with it in the loop with HOLMImpulse (or whatever; an audio interface with loopback is pretty useful here) you'll see the resulting distortion at low frequencies. I asked Jan about fixing this back in 2010 and he never responded. PLParEQ does overlap and window the buffers to produce very small and soft discontinuities but, as a result, uses quite a lot of CPU. It's also pretty expensive and that's after a 40% price drop when David sold Refined Audiometrics to Acudora.
I don't anticipate implementing a real time version of Cross Time DSP. The required window length in time reversed IIR goes to infinity as the center frequency of the correction goes to zero just like the number of taps in a phase correcting FIR goes to infinity. Time reversed IIR scales more poorly in terms of storage than FIR since with FIR there's only one window whereas IIR has to have multiple ones---actually quite a few of them if you're trying to make the merging between windows gentle enough to keep the numerical THD low enough that the platform's performance limits on -100 to -120dB THD in the DAC. So you tend to end up wanting something like a SHARC with an external RAM to run it on, though some applications fit in a single Cortex M4 with external RAM. I'm entirely capable of DIYing that but the VisualDSP++ license for the SHARC costs more than my entire stereo system and all of my instruments combined and a rackmount Atom still entails the overhead of keeping one's PC patched and having an audio interface for it. A multi-core M4 board would be kind of fun but, given how easy it is to do the reverse time pass once on my laptop at burn time and avoid the need for overlapping windows and computation, it's a low priority project. I have years' worth of higher priority projects...
1024 taps should be enough to correct even a LR 48khz at 100Hz with only minor phase deviation down low (and of course any other additional filter at higher frequencies).
The phase corrections on my subwoofers are LR4 at 40Hz and LR6 at 200Hz---the speaker build is documented in this thread. Blackman seemed to be the best window for doing the phase linearization, 200Hz LR6 XO, and dipole and driver EQ in a single filter at 44.1kHz (redbook). I agree rectangular's a better choice for phase linearization alone but of course it produces unhappy stopband attenuation on an XO. I didn't look especially hard at two FIR filter approaches but I didn't find any that resulted in a reduced number of taps. Probably the best way to go about it would be high precision IIR for XO and EQ and FIR for phase linearization. That seems to want around 2000 taps, more or less in line with your estimate.
fft convolution lead to much more taps available, still with less rounding errors than biquads
Well then, sir, you need better biquads. You can find a basic implementation here.
I think FIR has a bad reputation because it is always associated with semi-automated correction tools (which are sometimes really good, but require far more knowledge than it seems to operate correctly and not introduce more problems than solutions), steep filters (brickwall...), and delay.
For me it's mainly FIR CPU and storage requirements that shift the optimum solution IIR, though I have applications where delay is a factor as well. For cost effective, simple forward time phase correction FIR is certainly hard to beat and the miniSHARC is quite interesting as a way of enabling corrections at lower normalized frequencies. 800MMACs is somewhere around 18,000 total taps which is enough to run even my fairly demanding low frequency phase corrections, XO, and EQ all in FIR on redbook. Which is no bad thing as miniDSP probably isn't going to support biquads wth 64 bit coefficients and feedback. However, there are some things I want to explore which require more control over the platform than miniDSP has historically provided and that, in turn, leads me to choose less powerful hardware which can't crunch the FIRs I require. So I'm in IIR space for the time being, though the amount of taps a SHARC can get through with 1.2W of dissipation is pretty cool.
Old 23rd December 2012, 07:38 PM   #27
thierry38 is offline thierry38  France
  • Passive filter
yes,to check the phase linearization,export from rephase with .txt file.
import impulse.txt with holm,you can see the opposite curve applied in the convoluton engine.
only a single stereo convolution is needed in front of crossover (analog,IIR,passive)
a better way is to make a mic measurement of loudspeaker,aplly theoritical phase rotation and adjust with the phase EQ tab in rePhase.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Old 23rd December 2012, 07:49 PM   #28
Default two small feature requests
It's not well known, but the ES9016 and ES9018 DACs support user specified antialiasing filters. One interesting use of rePhase is to explore what sort of constrained phase response filters could be programmed into these DACs. However, this is difficult with the 0.9.2 build as it's limited to a maximum sampling rate of 192kHz and a maximum frequency in the response graph of 30kHz.
pos, if you could
1) add 352.8kHz, 384kHz, 705.6kHz, 768kHz, 1.4112MHz, and 1.536MHz to the list of supported sampling rates
2) add an option to select or specify the graph's maximum frequency (a checkbox for 30kHz versus Nyquist would be sufficient, though more granular control would be nice)
checking out these design possibilities would be quite a bit easier since the relevant sampling rate could be specified and the response seen. I'd make this change but I don't see source code available at sourceforge.
Old 23rd December 2012, 08:37 PM   #29
pos's Avatar
Dave.
Thank you Dave!
Would you care to elaborate on your configuration and the gain you hear with phase linearization?
From the feedbacks I have so far it looks like it is more noticeable for low frequency crossovers (for example the subwoofer crossover), but I would be curious to have your opinion in a 3 way. What are your crossover frequencies?
Old 23rd December 2012, 08:43 PM   #30
pos's Avatar
  • Passive filter
Correct
When the motivation comes back I will try add a measurement import feature in a next version, to alleviate the need to check the impulse with HOLM (or REW) and be able to see the effect of a correction in realtime.
In the meantime you will have to use the C=A*B feature in either HOLM or REW...
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
