Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Transmission Line Modelling Software
Old 4th April 2019, 03:51 PM   #881
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Yes, just model it as a single composite driver (ie 2 x Vas, same Qt/Fs…) with drivers placed such that Zd is the midpoint betwen the drivers.
Martin King has a doc on his site (TWT Amplifiers, Traveling Wave Tube Amplifiers, Microwave Amplifiers, Power Supplies) that details this. The whole site is required reading if you are doing a TL.
dave
Note: i deleted the thread you started with the same question.
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th April 2019, 04:02 PM   #882
grubby is offline grubby  United States
dave
Thanks for the response. Is there a thread or information on how you handle all of the Thiele parameters when using multiple drivers? Also does it matter if the drivers are in parallel or series?
Old 4th April 2019, 07:15 PM   #883
LightBit is offline LightBit  Slovenia
LightBit's Avatar
This is correct web site: Quarter Wavelength Loudspeaker Design
SpeakerSim - speaker simulation software
Old 15th May 2019, 08:14 PM   #884
Frankenspeakers is offline Frankenspeakers  United States
Originally Posted by 3ll3d00d View Post
the zip must be extracted to C:\tline_installer otherwise it won't work, i.e. you will have c:\tline_installer\TransmissionLine.application and then a subdir named AF which has the other files in it. Double click the application file and it should install normally without needing any webserver or external site.
OK What am I doing wrong?
Old 16th May 2019, 03:28 AM   #885
GM is offline GM  United States
GM's Avatar
Dunno, I thought I did the workaround right when mine crashed last year, but still get a .NET error.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th May 2019, 03:44 AM   #886
perceval is offline perceval  Taiwan
perceval's Avatar
You seem to have two line_installer folders.
looking at your navigation window, you have tline_installer>tline_installer>TransmissionLine.a pp.
Move the middle folder to the root of C:/
Transmission Line Modelling SoftwareHide this!Advertise here!
TLwrx v 3.0 Transmission Line Software CarlosT Subwoofers 16 27th March 2008 04:25 PM
3 Way Crossover modelling Software? Grahame Multi-Way 3 13th May 2007 04:50 AM
Matlab-based triode modelling software Radames Tubes / Valves 1 16th September 2005 07:36 PM
3d modelling software greg_mcquaid Multi-Way 17 22nd May 2004 07:03 AM
Copyright ©1999-2019 diyAudio
