Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HOLMImpulse: Measuring Frequency- & Impulse-Response
Old 21st January 2016, 06:39 AM   #1011
Pano is offline Pano  United States
Pano's Avatar
Tony, I'll look at that, thanks. Mario, no need to send and example impulse - nothing works. Even files that had worked before.
Take the Speaker Voltage Test!
Old 21st January 2016, 06:51 AM   #1012
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Oh and do make a copy of the zip file if you have any measurements in it you want to keep! (or export if that is still working).
Tony.
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Old 23rd January 2016, 02:38 PM   #1013
jtalden is offline jtalden  United States
Originally Posted by Pano View Post
Anyone else having new problems with HOLM? I'm running v1.4.2 (x64) on Windows 8.1 64 bit. It has suddenly gone wonky.
It will not import an impulse file, no matter what the format. I won't even import an impulse it just exported.
It will import in the 2 file tab, where you can bring in a Signal and Recording. I use this to cheat and bring in impulse files.
It will not do any Manipulations, such as C=A*B or C=A/B, unless I close it and reopen it fresh.
These are problems that I've never seen before as long as I've used HOLM. I did a re-install and it still has the same problems. Could this be a .net framework change or something?
FYI:
I have had the same problems for a long time with both 32 and 64 bit versions of Holm. Now using windows 10, but it was the same when using windows 7. I didn't realize others can successfully import IRs. I hope someone has a solution.
Pano, Thanks for the workaround. I will give that try.
Old 24th January 2016, 12:16 AM   #1014
Pano's Avatar
You're welcome. What I did was make an ideal impulse to be used as the Signal. Just one sample on. You can import a Recording (your impulse) to compare against the ideal impulse. Use the same sample rate, of course.
Tony, I dumped all the HOLM user data but to no avail. It still crashes when trying to import an impulse by itself.
Old 24th January 2016, 11:29 AM   #1015
just another
wintermute's Avatar
Hmmm that doesn't sound promising. I guess it could be an incompatibility with whatever the latest .net patches are. I hope not, as it could be the death of it, since there has been no development for a long time.
Are all the other things still not working either?
Tony.
Old 24th January 2016, 11:53 AM   #1016
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
I found the same (windows 7 and 8.1) for wavs, I used to just use the "import from text file" option instead (which also, iirc, crashes if the file contains anything other than the data)
Old 24th January 2016, 12:17 PM   #1017
I tried Pano's workaround for importing IR '.wav' files and it works great.
When IR math 'manipulation' stops working I have also just saved the file and reopened it. The 'manipulation' feature can then be used again.
I have not run into any issues with the rest of the program features.
Old 10th March 2016, 08:09 PM   #1018
RTipton is offline RTipton  United States
I'm having a problem too: Windows 7 Home Premium. Export does not work at all which makes Holm Impulse rather useless. From the discussions of these other problems, maybe no solution. Has anybody tried going back to an older version of NET Framework?
Old 24th March 2016, 10:29 AM   #1019
tthorsten is offline tthorsten  Germany
kick
Old 5th October 2016, 01:50 AM   #1020
Toberius is offline Toberius  Argentina
Toberius's Avatar
Hi, I have a issue with holmimpulse x64, I run windows 10 with .NET framwork 4.6.2 any else have issue running W10 with .NET framwork 4.6.2?
Regards.
HOLMImpulse: Measuring Frequency- & Impulse-ResponseHide this!Advertise here!
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 01:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 07:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 01:26 PM
Copyright ©1999-2019 diyAudio
