Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HOLMImpulse: Measuring Frequency- & Impulse-Response
Old 18th November 2015, 11:43 PM   #1001
jtalden is offline jtalden  United States
I struggled to work out a 2-Tone method using my equipment, but was finally was able to conduct a reasonable test and analysis. Audacity was used to create a 6-tone signal and also to record it being played.
Below are the results of the '2-Tone' measurement Vs a Holm sweep measurement using the same setup and signal path.
Pretty good agreement considering the less than ideal process used for the 2-Tone test.
Old 19th November 2015, 12:43 AM   #1002
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by Pano View Post
Correct. I did this a few pages ago and got the same results for phase in several softwares. That's because they are all doing it wrong, you know.
Earl Geddes Gedlee Website
Old 20th November 2015, 11:58 PM   #1003
Pano is offline Pano  United States
Pano's Avatar
JT good work! How did you determine phase in your recorded file? Did you look at zero crossing delays and calculate from there, or some other method?
Take the Speaker Voltage Test!
Old 21st November 2015, 03:46 AM   #1004
Pano,
Zero crossing would probably have work okay also, but there was a little very low freq swing ('DC offset') in some of the recorded signal that shifted the wave up/down by a small amount. That made me think that the zero crossing would have more variability in position than just using my best estimate of the peaks.
Then I found the low freq peaks (100, 200Hz) also contained a little noise that made identifying the peak accurately a little difficult so I decided to measure over several cycles of each burst and take the offset of the averages of the Signal Vs the Capture to help minimize the error.
The following are my notes from the experiment. Also attached is the full chart of the collected data and a couple other charts.
Process Summary
2-Tone test:
> Audacity used to create a .wav file containing tone bursts of 100ms each for 6 different frequencies. Each burst was separated by 500ms of silence.
> Mic was centered on speaker ~10cm from the baffle (SEAS 7" MW).
> XO and EQ was disabled so driver response in a sealed box was measured.
> The 2-Tone file was played by a DLNA server through my theater instrument rack and was recorded using Audacity on a Notebook PC used for all my audio measurements.
HolmImpulse Test:
> Exported the Holm signal to a .wav file so it could also be sent via DLNA so the measuring equipment would be identical for the 2 processes.
> Disabled the Holm soundcard and mic cal files.
> Took 6 measurements to assure that there was high repeatability. There was, so only the first measurement was used.
> Made a slight adjustment to the IR position to align the phase at 3200Hz to 0.0 degrees.
> Exported the SPL/Phase text file to read the phase at the 6 frequencies (placed that in last row in the table).
Analysis:
> Scaled the Signal SPL to approximate the Captured SPL level for each burst.
> Time aligned the 2-Tone signal and the 2-Tone Capture at 3200Hz in Audacity.
> Used Audacity to measure the sample offset of the Captured .wav Vs the Signal .wav for each of the 6 frequencies.
> Since the sample offset varied a little due to noise in the captured .wav an average was used across several cycles for each of the 6 captured bursts.
The repeatability and accuracy of the 2-Tone method I used here is not as good as using Holm or other audio analyzer, but agreement is good enough to suggest that the 2-Tone test can be used with reasonable accuracy. A better process would probably increase the accuracy, but the time requirement makes the method impractical.
Old 21st November 2015, 04:10 AM   #1005
Pano's Avatar
Excellent! That is very close to what I wanted to do, a file that contains several blocks of frequencies to compare. Looks like it works very well.
Good work on the averaging. When the phase shift is large, it's got to be easier to see. The small shifts must have been difficult to calculate. Nicely done, sir.
I think we can put this bugaboo to rest now.
Old 16th January 2016, 07:08 AM   #1006
vladimirb0b is offline vladimirb0b  United States
Couldn't find this answer in the thread:
I would like to take several measurements and average them. For the purpose of generating filters could I just use the sum function and not worry about dividing by the number of samples?
Old 16th January 2016, 01:11 PM   #1007
Yes, just summing them works fine.
The amplitude is increased, but that does not impact SPL shape for the purpose of creating EQ filters.
If you want to shift the overall level back down to the average level for any reason you can offset the level by:
dB offset = -20LOG(N)
Where N is number of measurements averaged.
Old 20th January 2016, 04:18 PM   #1008
Pano's Avatar
Default Strange New Problems
Anyone else having new problems with HOLM? I'm running v1.4.2 (x64) on Windows 8.1 64 bit. It has suddenly gone wonky.
It will not import an impulse file, no matter what the format. I won't even import an impulse it just exported.
It will import in the 2 file tab, where you can bring in a Signal and Recording. I use this to cheat and bring in impulse files.
It will not do any Manipulations, such as C=A*B or C=A/B, unless I close it and reopen it fresh.
These are problems that I've never seen before as long as I've used HOLM. I did a re-install and it still has the same problems. Could this be a .net framework change or something?
Old 20th January 2016, 07:20 PM   #1009
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
hmm, whenever I have anything weird happen with holm I find the dir it stores the zip file in that has all of the measurements (there are a couple of other files too) and blow them all away. restart holm and it creates new ones (all settings go back to defaults) and it usually fixes it.. I think it is under something like c{\users\yourusername\appdata\roaming\holm impulse) do a search under c:\users\yourusername I've not got holmimpulse on this work laptop...
Tony.
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Old 20th January 2016, 07:39 PM   #1010
Mario Pankov is offline Mario Pankov  Europe
Can you send me the impulse file you`re having trouble with?
The only problem I`m having is that if I use Holm for a longer period, it would make all audio players unusable. Even youtube won`t start. Might be a setting I`m missing?
HOLMImpulse: Measuring Frequency- & Impulse-ResponseHide this!Advertise here!
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 12:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 06:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 12:26 PM
Copyright ©1999-2019 diyAudio
