Go Back   Home > Forums > > >
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
★★ Free PCB for JLH 2005 Class-A Amplifier
Thread Tools
Old 27th December 2017, 02:11 PM   #311
Puffin is offline Puffin  United Kingdom
I built one of these amps using the Siliconray boards some years ago which hasn't been used. I recently ran it for a few days and had problems with the L channel blowing the pcb fuse. Having checked it over it seems that I can't now get the dc offset down and my light bulb tester is glowing brightly when the L channel only is connected (dual mono double psu design)
I Built the board using TIP3055 transistors. My electronics knowledge has increased a little since I built that amp and I have a few questions I wonder if anyone can answer.
I used the TIP 3055's in both positions on the board, but now wonder whether they should both be the same or whether one of them should have been a P channel 2955. I am probably going to replace all the output transistors on both boards and wondered which ones would be favourite for the board's interpretation of the JLH amp.
Old 25th February 2021, 12:55 PM   #312
I had forgotten about the above post. The amp has not been fixed. Anyone?
Old 29th August 2021, 09:29 PM   #313
haiqu is offline haiqu  Australia
haiqu's Avatar
The obvious thing to do is Google for a circuit diagram to answer the transistor question.
“The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side.” - Hunter S. Thompson
Old 29th August 2021, 09:50 PM   #314
huggygood is offline huggygood  France
huggygood's Avatar
this pattern has never been stable.
I tried several things but nothing worked, it swayed, I gave up.
Tempus fugit
Old 29th August 2021, 09:53 PM   #315
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
I have these boards, still unfinished, in a drawer...
I've attached zip file with board and schematic images. If I recall correctly there are several posts earlier in this thread that purport to describe the set-up process.
I did finish the SiliconRay headphone version and it worked well and sounded good.
Old 30th August 2021, 05:51 AM   #316
EUVL is offline EUVL  Europe
Why not use the original, proven by many.
Geoff Moss's JLH-2005 design files
Patrick
xen-audio.com
Old 30th August 2021, 06:52 AM   #317
And here the original Gerber data from Geoff Moss :
Patrick
xen-audio.com
Old 30th August 2021, 07:46 AM   #318
polsol is offline polsol  South Africa
Just saw this post this am.
The output transistors were specified as both being MJ15003 (NPN).
The trick (from memory) is to set both pots mid way and then adjust for quiescent current followed by output voltage (to 0V).
Repeat adjustments until the quiescent current and output voltage are stable (probably 3 to 5 times) making sure the heatsink(s) temperature is stable (at 'operating temperature') each time.
Have no issues with the amps per se. Sound is very good.
The problem is some 50Hz 'hum' in my setup which arises from the power supply I used. One really needs a lot of capacitance or something like a ripple eater to maintain a steady current to these amps with minimal ripple. Mine is 2 separate power supplies with 20,000 uF per channel (without opening the case). I think 47,000 uF per channel in a standard configuration PSU would probably be a minimum (untested).
HTH
Tony M
Old 31st August 2021, 09:51 AM   #319
Found this PDF file I'd made which provides schematic and adjustments in my handwriting.
Hope you can read it.
Tony M
  Reply to this post
★★ Free PCB for JLH 2005 Class-A AmplifierHide this!Advertise here!
Thread Tools
★BR Bookshelf Cabinets for Mark Audio CHR-70, Special Price:$65/pair only Musik007 Twin Audio 112 15th August 2013 06:20 PM
My JLH-2005 siliconray Solid State 4 14th November 2011 11:51 AM
PCB for JLH Class A Amplifier Akita Swap Meet 1 11th October 2011 05:10 AM
Wanted JLH Class A Phone Amp Pcb overlay colin.hepburn2 Solid State 2 21st February 2003 09:48 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
