Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
Soft baffles - surely these will help?
Old 6th July 2019, 08:41 AM   #1
zerokelvin99 is offline zerokelvin99  United Kingdom
Question Soft baffles - surely these will help?
I have a pair of wall mounted 5.5" tops, and was thinking of using some excess rockwool RW3 (60Kg/m3) to create a soft baffle increase, in the hope of reducing both boundary interference and also baffle diffraction.
I was originally hoping to mount as below, but still would keep the baffle diffraction issues:
Hence, moving to a "pyramid" type scheme as as below. This would be quite a pain to make.. Do you feel it would be worth it?
Worth it or shall I put my efforts elsewhere??
Old 6th July 2019, 08:53 AM   #2
Bill Coltrane is offline Bill Coltrane  Netherlands
Diffraction occurs when there's a change of acoustic impedance.
So to minimize it, limit the impedance change.
An option I would consider is to use wood instead of rockwool at 45 degrees angle or less and make a pyramid.
Subjective measurements with the proper protocol is the only thing that matters.
Old 6th July 2019, 08:57 AM   #3
Quick reply, thanks!
I just have so much of the bloody rockwool left
Do you feel 45 degrees would suffice? Is it worth rounding the edge next to the speaker and keeping it tangential?
May try it in wood tomorrow if I get the chance,
Old 6th July 2019, 09:08 AM   #4
Less degrees is less impedance change, so less diffraction. I don't know what is optimal.
Then there is baffle step compensation to take into account. If you change the box, this must change to. So you probably need to change the crossover to.
But I think it is fun experimenting with this.
Old 6th July 2019, 09:10 AM   #5
I run the speakers through a miniDSP, so not too worried about the baffle step compensation. If there is a simple passive filter I can compensate for it!
I think 45deg is the best starting point for WAF maybe.. I'll see how it goes from there!
Old 6th July 2019, 09:21 AM   #6
With minidsp you can compensate for baffle step.
Measure off axis to!
Soft baffles - surely these will help?Hide this!Advertise here!
Pyle 21" driver: Surely this cannot be. Jameson Styles Subwoofers 112 4th June 2018 06:20 AM
Power soft start board / amp delay soft start board what is it ??? thesaintxxx Power Supplies 5 18th September 2016 06:38 AM
Surely, that's insane ?! philpoole Digital Source 2 6th August 2009 09:06 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Surely this must be be evidence of an addictive personality? leadbelly Multi-Way 11 1st February 2004 04:12 PM
Copyright ©1999-2019 diyAudio
