Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
Plywood or plaster board?
Old 3rd September 2019, 01:02 AM   #11
oohms is offline oohms  Australia
It depends what properties you want.. thick plasterboard stops a lot of sound transmission but you get the reflections. I imagine a material that reflects less would also let more sound transmit through it
You will most likely need additional sound treatment regardless if your choice
Old 3rd October 2019, 06:47 PM   #12
Retsel is offline Retsel  United States
Default Acoustic Fields recommends plywood
The sound engineer at Acoustic Fields says that hardwood veneered plywood has a better tone quality than drywall. They also say that the plywood, by virtue of the layering, has better internal dampening than drywall.
I am leaning toward plywood for my home theater/audio room build instead of drywall. Also, I am not concerned so about sound transmission out of the room, so I may opt for thinner plywood to help the bass escape which will help to avoid the creation of room modes compared to more stout wall material (i.e., double 5/8 inch drywall).
Retsel
Old 3rd October 2019, 06:55 PM   #13
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Anyone ever tried Homasote? (It's commonly used for model railroads because plywood transmits too much sound.)
Plywood or plaster board?Hide this!Advertise here!
Acoustic treatment help for plaster walls? batsong Construction Tips 0 25th June 2013 05:24 AM
Marc1 Proust, 2way 8" waveguide & 5.5"mid, plaster and corks. Studio Au Multi-Way 14 4th September 2012 02:02 PM
Plywood or MDF? greg_mcquaid Subwoofers 30 10th July 2011 06:37 AM
Turntable platter from plaster magentawhale Analogue Source 24 31st August 2008 02:47 AM
plywood instead of MDF? jdeare Multi-Way 2 21st February 2003 12:36 PM
Copyright ©1999-2019 diyAudio
