Ordered 4 sets of these:
https://www.parts-express.com/dayton-audio-dss4-g-gold-speaker-spike-set-4-pcs--240-718
And two of these today:
Oh and a rivnut gun.
The plan is to hack & stack them with the bottom shelf of the lower one at floor level to make room for some LPs on the bottom and place turntable, amp and Nativ streamer on the top shelf with some cassete deck, CD etc in between.
I've ordered enough spikes to create some separate isolation platforms if required. The shelves aren't as solid as they look in the photo so I might invert them and fill them with sand and seal them up for a bit more. dampening.
Choice between store bought racks seems to go from very cheap and Nasty to stupid money very quickly. I know from speakers stands Iv'e owned and built that sand or lead shot makes a useful difference.
I should get this little lot worked up into something useful made of real wood and steel for a bit more than $1000NZD better than the $1000 - $4000 a shelf I've been quoted.
Any thoughts.
Any thoughts.
Why not?
Also lead and rubber sheets could be useful.
I do not like generic use of rivets: screws, bolts , glue and wooden pins are better. IMO .
Parts express Spikes have inserts for threading into wood but use M6 threads so it seems like a plan to use M6 rivnuts for the feet into the steel box section.
I found someone on line in NZ that sells 10kg bags of lead shot for $110NZD it would be good to fill the hollow box sections with that. I used to have a pair of AE1 M1 speakers with dedicated stands filled with shot it works well.
See how we go.
See how we go.
I did a search and looks like you can get them via Target in the USA.
West End Coffee Table
SKU CSWESTCOFF
Target Furniture NZ | Modern Designs at Affordable Prices |
Too low for my needs, don't trust my ability to stack them safely and doubt they are "Acacia timber", most likely a veneer over some cheap MDF.
I can build better for $500, but then I'd have to get off the computer and actually do it.
SKU CSWESTCOFF
Description
The beauty of natural brushed Acacia timber combined with contemporary matt powder coated metal makes for a truly industrial chic collection.
Easy DIY equipment racks made with plywood & black pipe fittings.
I like black gas line pipe so much better than the threaded rod designs.
Nice work.
I should get around to posting some of my black gas line pipe and plywood projects.
Dayton Audio DSS4-G Gold Speaker Spike Set 4 Pcs.
And two of these today: View attachment 731880
Any thoughts.
What is the weight limit on the table?
“What is the weight limit on the table?
Thanks“. The steel was strong enough but the tops are hollowed out. I screwed blockboard inside the top shelf to give it more mass and less potential resonance. You can turn each shelf into a torsion box making it very rigid. Because of earth quakes I have the two halves strapped together using heavy duty tie wraps.
Thanks Steve!
- General Interest
- Room Acoustics & Mods
- DIY Equipment rack
