Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
Room Volume and Bass Speaker Size
Old 15th January 2019, 11:48 AM   #11
Veeren is offline Veeren  Portugal
Default Room Volume and Bass Speaker Size
Yes scottjoplin it is near the backwall.
No bicicletta, not open baffle the idea was to use the 2 front corner walls as part of a closed box of about 80 litres so I would only need the front baffle and the top to make a cabinet.
Thanks!
Regards, Veeren
Old 15th January 2019, 12:34 PM   #12
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Where the sound wave isn't moving, i.e. near a wall, pressure can build up, this is probably what you are feeling, try moving your listening position away from the wall.
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 15th January 2019, 12:45 PM   #13
Vix is offline Vix  Yugoslavia
Vix's Avatar
From my experience, the unfortunate circumstance is that there's not much place to move in a small room, i.e. listening position can be "stuck" near a wall and one have to live with it. Now, some speakars can sound better in such occasions, some worse. Now I am using an OB (but they too need a fair distance from the wall). I have another set od Diy Omni speakes which proved to sound good in such small rooms....
Old 16th January 2019, 12:04 PM   #14
Bicicletta is offline Bicicletta
It is good that those 80l are sealed, so, IMO, it is more convenient to build a 6-wall box.
I like the Vix's solution.
Room Volume and Bass Speaker SizeHide this!Advertise here!
Bass driver vs room size JRKO Room Acoustics & Mods 109 8th August 2017 05:36 PM
Correct Speaker For Room Size peterpan Room Acoustics & Mods 12 17th April 2015 03:20 AM
speaker low end and room size : which ratio? Eldam Room Acoustics & Mods 57 19th September 2013 01:53 PM
volume displacement vs room size soundnovice Room Acoustics & Mods 4 24th March 2013 11:55 AM
Speaker size v Room size cliffy Room Acoustics & Mods 6 19th February 2005 09:34 AM
Copyright ©1999-2019 diyAudio
