Room Acoustics & Mods A place to discuss measuring and modifying room Acoustics for better sound
Horrible 110 Hz problem in my living room
Old 8th November 2018, 10:12 PM   #1
andreaemme is offline andreaemme  Italy
Default Horrible 110 Hz problem in my living room
Hello! I'd want to share with you a problem that is going to make me become mad.. I've bought a pair of Indiana Line Tesi 561 like these, wonderful loudspeakers, but in my actual configuration:
listening jazz, I hear a terrible and troublesome resonance in the upper bass region. I've made some measurements with a common phonometer and I've found that there's a very narrow peak centered aorund 110 Hz. Otherwise, around 90 Hz there's another narrow negative peak, so between 90 and 110 Hz there's about 20 dB of difference, more testing right loudspeaker than the left one.
The strange thing is that I've never heard this with my previous DIY loudpspeaker in the same position, all with a unique 8'' driver. Supposing an internal resonance of loudspeaer, I've tried to fill cabinets with polyestere but only stuffing entire cab problem is quite solved, while bass disappears..
110 Hz peak is centered only in my listening position, walking around there's no problem, but I can't change disposal of my living..
What can I do in your opinion to correct this?
Thank you very much.
Old 8th November 2018, 10:27 PM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Hello. I'm afraid your listening position couldn't be much worse, I almost guarantee the problem is the wall directly behind you, there are always peaks close to walls
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 8th November 2018, 10:32 PM   #3
Windforce85 is offline Windforce85  Poland
You're sitting at the rigid wall inside of rectangular room and your new toys finally reproduce 110Hz efficiently. It is perfectly normal. In order to prevent such problem say sorry to your current room arrangement and try this (attachment).
Old 8th November 2018, 10:48 PM   #4
..nooooo...what a despair..! Thank you very much, but really there's nothing I can do to prevent this? As installing some panel behind sofa..? I haven't said that upon my head when I seat ther's a pensile that breaks wall surface, but not large as sofa so around it there's open and flat surface..
Can covering nearest part of wall with planar bass traps solve in your opinion?
And why 90 Hz causes a counter effect than 110 Hz..?
Old 8th November 2018, 11:02 PM   #5
You can install whatever you want and throw your money away heading for weak or no effect becouse of inherent trouble of taming 3-meter wave. Changing listening triangle position is as usual the cheapest and most efficient way of improving listening experience. Strong interefences of incoming wavefronts from perpendicular walls in this particular sofa place are causing 110-90 Hz jump. Move away the sofa first and loudspeaker next from its current positions.
Old 8th November 2018, 11:06 PM   #6
You could try cutting the peak but don't try to boost the null, or if you do, and it works, only a little, say 6dB max
Old 9th November 2018, 12:02 PM   #7
Thank you very much for your precious and life-saving suggestions! I'll have to fight hard with my wife.. However, one change is really possible, inverting sofa and loudspeaker/tv position, so no wall will be behind me and speakers will be near wall, what do you think about this?
However, I use Fobar2000 with wasapi usb driver and a Audiolab M-DAC, do you know any good software parametric equalizer I can use to try taming the actual 3 meters wave cutting 110 Hz peak?
Old 10th November 2018, 04:50 AM   #8
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Ideally, neither the seat nor the speakers ahould be close to a walk (some speakers designed for against the wall excepted). Even 400mm will help.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old Yesterday, 08:26 AM   #9
Thank you very much!
I've tried some alternative way in these days, including a trial of a Digital Room Correction, but the best is to move forward sofa of about 50-70 cm every listening session, going off the wall behind, so I obtain a big improvement about 110 hz problem. Now being lowest bass a bit weak due to the wall center position of a loudspeaker that should be near a wall, I ask you what real benefit I should obtain moving their reflex vent (actually mounted on the front panel at about 50 cm distance from floor, tuned at about 40 Hz) on the bottom panel, raising cabinet from floor of about 3-4 cm and obtaining a down-firing vent. What can I expect from this solution in terms of improvement for the extremely low bass region?
Thanks.
Old Yesterday, 10:42 AM   #10
AllenB is offline AllenB  Australia
You will change the location of the source. Have you considered multi-subs?
Horrible 110 Hz problem in my living roomHide this!Advertise here!
Best speaker design for living room jreyes225 Full Range 44 20th October 2018 11:53 PM
Looking for a Tube Kit Amp for my Living room HarryY Tubes / Valves 11 24th October 2017 05:05 AM
5-way active filtered living room set juulmaessen Multi-Way 41 18th October 2017 09:08 PM
HORRIBLE room acoustics? asauer Room Acoustics & Mods 9 14th February 2004 05:25 PM
Hello from my living room. Which is in Oregon m00n Introductions 5 10th February 2004 03:31 AM
